BT.com
Wishlist
D-Link N QUAD GIG POE MAN ACCESS POIN W/ PLENUM CHASSIS
D-Link N QUAD GIG POE MAN ACCESS...
£208.68
£208.68
Add to wishlist
Delivery
Standard Due date unavailable
The DAP-2690 is a dual-band wireless access point, designed to enable businesses of any size deploy wireless networks. Enclosed in a rugged, plenum-rated metal chassis, the DAP-2690 adheres to strict fire codes for placement in air passageways.
D-Link AirPremier N Simultaneous Dual Band PoE Access Point with Plenum-rated Chassis DAP-2690 - radio access point
Radio access point
External - indoor
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Power Over Ethernet (PoE) Supported
PoE
19.1 cm x 19.9 cm x 3.7 cm
1 kg
Radio access point
Ruggedized Design
Indoor
19.1 cm
19.9 cm
3.7 cm
1 kg
External
Wireless
Data Transfer Rate
300 Mbps
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH
VLAN support, MAC address filtering, Wireless Distribution System (WDS) support, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Network Access Protection (NAP)
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
Authentication Method
RADIUS, Radio Service Set ID (SSID)
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11n
Aerial
Antenna
External detachable
Antenna Qty
4
1 x 1000Base-T - RJ-45
Mounting Kit
Included
CSA, C-Tick, IC, FCC
PoE
10 - 90%
Scroll to top
