BT.com
Wishlist
D-Link mydlink Home Monitor 360
Delivery
Standard 1-3 working days
The mydlink Home Monitor 360 allows you to monitor your home, whenever, from wherever. Not only does it pan and tilt to cover wider areas, the built-in night vision allows you to see up to 8 meters even in complete darkness. It's easy to setup, connects to your home Wi-Fi and can even alert you when motion is detected. What's more, it works with other mydlink Home smart devices to enable you to create a smart home without complicated setup, installation cost or monthly subscription charges.
mydlink Home Monitor 360 - network surveillance camera
Network surveillance camera - pan / tilt
Audio
Yes: built-in microphone
10.127 cm x 10.235 cm x 13.36 cm
292.4 g
Wired, wireless
Camera
Colour - Day&Night
Max Resolution
640 x 480
Frame Rate
30 frames per second
Optical Sensor Type
CMOS - 1/5"
Minimum Illumination
0 lux - IR - F2.0
Focal Length Control
Fixed focal
Focal Length
2.2 mm
Lens Iris
F/2.0
Panning Range (degree)
-170 to +170
Tilting Range (degree)
-25 to +95
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Voltage
DC 12 V
Motion sensor, date/time stamp, progressive scanning, saturation control, brightness control, contrast control, infrared cut filter, Wi-Fi Protected Setup (WPS), text stamp, notification picture to E-mail, notification picture to FTP, password protection
Environmental Parameters (operating)
0 °C - 40 °C; 20 - 85% (non-condensing) relative humidity
Audio Support
Wired, wireless
10.127 cm
10.235 cm
13.36 cm
292.4 g
Camera
Colour - Day&Night - pan / tilt
Digital Video Format
MJPEG, H.264
Max Digital Video Resolution
640 x 480
Digital Zoom
4
Exposure Range
1/15 sec - 1/15000 sec
0 lux - IR - F2.0
Infrared Distance
8 m
Supported Image Formats
JPEG
Image Sensor
CMOS 1/5"
Lens Construction
Fixed focal
Focal Length
2.2 mm
Lens Iris
F/2.0
Horizontal Field of View (degree)
66.22
Vertical Field of View (degree)
49.08
Panning
Range (degree)
-170 to +170
Titling
Range (degree)
-25 to +95
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, UPnP, IPv4, PPPoE
C-Tick, FCC
Power Requirements
DC 12 V
Power adapter - external 8.64 Watt
Microsoft Windows Vista / XP / 7 / 8, Android 4.0 or later, Apple iOS 6.0 or later
Relative Humidity (operating)
Accessories
£3.74
£13.46
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.26
£52.42
Scroll to top
