BT.com
Wishlist
D-Link Mini KVM Switch Kit With USB Port for 2 PCs
Delivery
Standard Due date unavailable
The DKVM-2KU 2-port mini KVM (Keyboard, Video and Mouse) switch allows you to easily control 2 different PCs from a single set of keyboard, mouse, and VGA monitor, and to share a USB device with 2 PCs. It includes 2 sets of built-in cables for ready connection to 2 PCs.
If you have 2 PCs and need to use them at the same time, the DKVM-2KU saves you the money and space by allowing you to control your 2 computers from a set of keyboard, monitor and mouse. Or, you may have a better, bigger monitor and want to connect both PCs to it, the DKVM-2KU allows you to do this. 2 sets of cables are attached to the KVM switch ready for use, dispensing you of the need to prepare separate cables and connect them to the switch.
The DKVM-2KU supports VGA, SVGA, and MultiSync monitors at up to 2048 x 1536 resolution at 72Hz refresh rate. Support for Microsoft IntelliMouse is provided. There is also a control button located on the front panel that allows you to switch between the PCs.
A USB 2.0 port is built into this KVM switch to allow connection to a USB-supported device or a USB hub. This allows you to share your USB printer, scanner, card reader or other devices among the 2 connected PCs.
D-Link DKVM 2KU - KVM / USB switch - 2 ports - desktop
KVM / USB switch - 2 ports - PS/2
Enclosure Type
Desktop
Subtype
KVM
Ports
2 x KVM / USB
KVM Users Qty
1 local user
USB 2.0
10.4 cm x 6.2 cm x 2.8 cm
0.57 kg
Enclosure Type
Desktop
Subtype
KVM
Ports
2 x KVM / USB
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
PS/2
Max Resolution
2048 x 1536
USB 2.0
Status Indicators
Port status
2 x VGA - HD-15 , 2 x keyboard (PS/2) , 2 x mouse (PS/2) , 2 x USB - Type A , 1 x mouse (PS/2) , 1 x keyboard (PS/2) , 1 x VGA - HD-15 , 1 x USB - Type A
2 x keyboard / mouse / video / USB cable - 1.8 m
FCC Class B certified, C-Tick
10.4 cm
6.2 cm
2.8 cm
0.57 kg
0 - 80%
Scroll to top
