BT.com
Wishlist
D-Link INDOOR 802.11A/B/G/N ACC POINT UNIFIED W/ POE
Delivery
Standard Due date unavailable
The DWL-8600AP is a versatile and powerful indoor access point for business environments. With adjustable antennae the wireless signal can be optimized to given maximum data transmission speeds. The DWL-8600AP can be deployed as a standalone wireless Access Point or used as the foundation for a managed wireless network.
D-Link Wireless N Unified 802.11n Dualband Access Point DWL-8600AP - radio access point
Radio access point
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Power Over Ethernet (PoE) Supported
PoE
19.9 cm x 19.1 cm x 3.7 cm
1.02 kg
Radio access point
19.9 cm
19.1 cm
3.7 cm
1.02 kg
External
Wireless
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM
Spread Spectrum Method
OFDM, DSSS
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, SSH
Status Indicators
Power, status
Flow control, load balancing, Syslog support, auto-fallback, MAC address filtering, Wireless Distribution System (WDS) support, MIMO technology, Wi-Fi Multimedia (WMM) support, SpectraLink Voice Priority (SVP) support, Quality of Service (QoS), Data prioritization (Qos) for VoIP applications, wireless bridge mode
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, 152-bit WEP, TKIP, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
Authentication Method
RADIUS, Radio Service Set ID (SSID), Extensible Authentication Protocol (EAP)
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.3x, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11h, IEEE 802.11n
Aerial
Antenna
External detachable
Antenna Qty
4
Directivity
Omni-directional
1 x 1000Base-T - RJ-45
MTBF
523,721 hours
FCC Class B certified, CSA, UL, VCCI, C-Tick, ICES-003, EN 60601-1-2, TELEC
PoE
10 - 90%
Accessories
£3.69
£12.63
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£7.76
£49.24
Scroll to top
