BT.com
Wishlist
D-Link EyeOn Pet Monitor
Delivery
Standard 3-5 working days
Keep an eye on your beloved pet with the DCS-800L/P EyeOn™ Pet Monitor. This portable camera transforms your mobile device into a versatile, yet easy to use pet monitor. Connect to the camera wirelessly or over the Internet so you can check on your pet no matter where you are. It includes a wide array of features to help you look after your pet including night vision, motion and sound detection.
Peace of Mind, Anywhere, Anytime
The EyeOn™ Pet Monitor is specially designed to make it easy for you to care for your pet. It can detect movement and loud noises such as barking or meowing, and alert you via push notification. Its versatile all-day monitoring turns on night vision automatically when it gets dark, giving you a clear picture day or night so you can keep an eye on things anytime. It's perfect for use in the home, or even when you're away; it's mydlink™-enabled, which means that you can check on your pet remotely and securely over the Internet.
Perfectly Portable for Instant Monitoring Anywhere
You can take the EyeOn™ Pet Monitor with you when travelling with your pet, even when there is no available Internet connection. Just connect your mobile device to the EyeOn™ Pet Monitor's wireless network for instant local monitoring, making it perfect for family holidays or just visiting friends.
You can even connect it to an external USB battery for total portability!
Super Simple to Use
Getting started is quick and easy; the free mydlink™ Lite app for iOS and Android mobile devices not only guides you step by step through the setup process but also gives you an easy to use interface for all the advanced features of the EyeOn™ Pet Monitor. Check on your pet at a glance, pinch to zoom in and out with ease or play one of five gentle lullabies to soothe and calm your pet. You can even take snapshots and save them directly to your mobile device!
Just download the free mydlink™ Lite app for your smartphone or tablet and you can quickly and easily setup and view your EyeOn™ Pet Monitor from anywhere with a wireless or 4G LTE/3G connection. You can also log onto the secure mydlink™ web portal on your computer to see what your pet if up to.
  1. USB battery not included, requires at least 2 A output.
  2. 2-way audio is half-duplex.
D-Link DCS 800L/P EyeOn Pet Monitor - network surveillance camera
Network surveillance camera - fixed
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
7 cm x 7.5 cm x 10 cm
108 g
Wireless
Camera
Colour - Day&Night
Max Resolution
640 x 480
Optical Sensor Type
CMOS - 1/5" - 640 x 480
Minimum Illumination
0 lux - IR
Focal Length
2.44 mm
Lens Iris
F/2.4
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Voltage
DC 5 V
Motion sensor, date/time stamp, noise detection
Environmental Parameters (operating)
0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
Audio Support
Wireless
7 cm
7.5 cm
10 cm
108 g
Camera
Colour - Day&Night - fixed
Digital Video Format
H.264
Max Digital Video Resolution
640 x 480
Digital Zoom
4
0 lux - IR
Infrared LEDs
Infrared Distance
5 m
Supported Image Formats
JPEG
Image Sensor
640 x 480 CMOS 1/5"
Lens Construction
Focal Length
2.44 mm
Lens Iris
F/2.4
Horizontal Field of View (degree)
57
Vertical Field of View (degree)
42
Network Interface
Network Protocols
DHCP, HTTP, TCP/IP, UDP/IP, ARP, ICMP, HTTPS, UPnP, IPv4
Stand
C-Tick, IC, FCC
Power Requirements
DC 5 V - 1.5 A
Power adapter - external DC 5 V (50/60 Hz)
Android 4.0 or later, Apple iOS 5.1.1 or later
Relative Humidity (operating)
Scroll to top
