BT.com
Wishlist
D-Link DSP-W215/B mydlink Home Smart Plug
D-Link DSP-W215/B mydlink Home...
£44.61
£44.61
Add to wishlist
Delivery
Standard Due date unavailable
Turn appliances On/Off with the Mobile App, Instantly turn appliances on or off from your smartphone or tablet*.
Create On/Off Schedules for Your Appliances
Set your appliances to work for you whenever you want.
Protect Your Appliances
Integrated thermal sensor will automatically turn off overheating power sockets, giving you peace of mind.
Monitor Your Energy Use
Keep an eye on your energy usage and save money.
Your Life Can Be A Lot Easier With The Smart Plug
Turn things on and off from your smartphone or tablet* using the mobile app. The app is easy to use and it'll send you customised notifications.
Create On/Off Schedules For Your Devices
Your appliances should work for you whenever you want them to, right? We agree - and that's why we made the Smart Plug. You can set device schedules so that you walk into a brightly-lit home every day after work with your favourite song playing.
Really Easy Setup
Connect to an existing Wi-Fi network with a simple push of the Wi-Fi Protected Setup (WPS) button on the Smart Plug and on the router. It's hassle-free and gets you connected in minutes.
Let The Smart Plug Worry About The Unexpected
Keep an eye on your energy use. Know what each device's power consumption is. Monitor air conditioning usage in the summer or heat usage in the winter so you don't get a big surprise at the end of the month.
Save Money On Your Next Energy Bill
Keep an eye on your energy use. Know what each appliances' power consumption is. Monitor air conditioning usage in the summer or heat usage in the winter so you don't get a surprise at the end of the month.
  • the mydlink™ Home app is available for iPod touch, iPhone and iPad devices using iOS version 6.0 or later, and Android devices using Android version 4.0 or later.
Mydlink Home Smart Plug - smart plug
Smart plug
Wireless - 802.11n
Supported Host Device OS
Android 4.0 (Ice Cream Sandwich) or later, iOS 6 or later iOS, Android
1 year warranty
6.6 cm x 3.9 cm x 11.7 cm
Smart plug
Wireless - IEEE 802.11n
Thermal protection, energy usage statistics, push notification, power scheduling Wi-Fi Protected Setup (WPS)
Encryption Algorithm
WPA, WPA2
Warranty
1 year warranty
UL, FCC
6.6 cm
3.9 cm
11.7 cm
173 g
10 - 90% (non-condensing)
Scroll to top
