BT.com
Wishlist
D-Link DSL-3590L Wireless AC1900 Dual-Band ADSL2+ Router
Delivery
Standard 1-3 working days
The DSL-3590L Wireless AC1900 Dual-Band Gigabit ADSL2+ Modem Router is everything you need for high-speed Internet access for your entire home. It combines an ADSL2+ modem and high-end wireless router together to create a single, easy to use device that creates and shares an Internet connection for all your devices. Connect a storage drive to the USB 3.0 or 2.0 ports to effortlessly stream your digital media library to your TV, PC, tablet or mobile device via the built-in DLNA media server.
The D-Link DSL-3590L Wireless AC1900 Dual-Band Gigabit ADSL2+ Modem Router creates a blazing fast home network that connects all of your devices to your broadband Internet connection. Advanced AC SmartBeam technology brings you the future of high-bandwidth wireless connectivity, vastly increasing the speed and coverage of your network. This allows you to stream HD video, make Internet calls, and surf the Internet from every corner of your home without interruption. The high-power internal antennas send the signal into the furthest corners of your home, giving you a strong connection wherever you are. Gigabit Ethernet ports provide high-speed wired connections for up to four PCs or other devices.
The Wireless AC1900 Dual-Band Gigabit ADSL2+ Modem Router allows you to use the mydlink web portal and mobile apps to remotely access, view, and manage devices on your home network no matter where you are. See who's connected to your router, change settings, or block connections, all from any computer, smartphone or tablet. Parents can monitor what sites their children are visiting, and can stay informed and in control, even on the go.
The mydlink SharePort app allows you to connect a USB storage device to the DSL-3590L and instantly share documents, movies, pictures, and music with mobile devices. You can put your music library on a USB drive and share it with your entire household. You can show photos on the living room TV while a family member watches a movie on their mobile device. You can stream media files to multiple devices without interruption, or save them to your device for offline playback. The intuitive interface lets anyone immediately connect to a variety of entertainment options stored securely on your own storage device.
The DSL-3590L uses the latest Wireless AC technology, which can provide transfer rates of up to 1.9 Gbps (1300AC + 600N). The router operates on both the 2.4 GHz and 5 GHz wireless bands at the same time using concurrent dual-band technology and six internal antennas. This allows you to browse the web, chat and e-mail using the 5 GHz band on a computer, while simultaneously streaming digital media, playing online games, or making Internet voice calls on the 2.4 GHz band on your smartphone or tablet.
The antennas inside the DSL-3590L have been carefully designed to ensure that you will get little to no dead space in any environment. The high-powered amplifier sends the signal into the furthest corners of your home. Furthermore, the Wireless AC1900 Dual-Band Gigabit ADSL2+ Modem Router's multiple internal antennas improve wireless reception by adjusting antenna positions to where they are most needed to achieve the best possible performance.
Setting up the DSL-3590L is easy with the D-Link setup wizard. Simply open the setup utility and follow a few easy steps to get your home network connected. You can also set up a secure network with the touch of a button using Wi-Fi Protected Setup (WPS). Simply press the respective WPS buttons on both devices to instantly establish a secure connection to a new device.
D-Link DSL-3590L - wireless router - DSL modem - 802.11a/b/g/n/ac - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, ADSL2, ADSL2+
WAN Ports Qty
2
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.9 Gbps
Permanent virtual circuits (PVC): up to 8
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, PPPoA, DHCP
Routing Protocol
Static IP routing
Remote Management Protocol
HTTP
Firewall protection, NAT support, Stateful Packet Inspection (SPI), content filtering, VPN passthrough, URL filtering, firmware upgradable, MIMO technology, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), virtual server support, Wi-Fi Protected Setup (WPS), Green Ethernet, port forwarding, DLNA Media Server, SharePort Technology, cloud managed, Guest Zone support, Advanced AC SmartBeam technology
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3az, UPnP, IEEE 802.11ac
AC 120/230 V
12.35 cm x 10.2 cm x 22 cm
588 g
Apple MacOS X 10.4 or later, Microsoft Windows XP SP3, Microsoft Windows Vista / 7 / 8
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.9 Gbps
Routing Protocol
Static IP routing
HTTP
Encryption Algorithm
AES, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3az, UPnP, IEEE 802.11ac, RoHS, IPv6 Ready, RCM
Status Indicators
Power, WLAN, LAN, USB, ADSL, WPS, Internet
Communications
DSL modem
ADSL, ADSL2, ADSL2+
LAN: 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x ADSL2+ - RJ-11 , WAN / LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , USB 3.0: 1 x 9 pin USB Type A
Aerial
Aerial
Internal
Antenna Qty
6
External power adapter
AC 120/230 V
24 Watt
1 x network cable , 1 x phone cable
12.35 cm
10.2 cm
22 cm
588 g
10 - 95% (non-condensing)
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.63
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.13
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£19.78
£13.83
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£30.90
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£17.96
Scroll to top
