BT.com
Wishlist
D-Link DIR-810L Wireless AC750 Dual-Band Cloud Router
Delivery
Standard Due date unavailable
The DIR-810L Wireless AC750 Dual-Band Cloud Router is an affordable yet powerful wireless networking solution which combines high-speed Wi-Fi connectivity with dual-band technology and Fast Ethernet ports to deliver a seamless networking experience. The DIR-810L also includes a host of security features to keep your network safe, while integrated cloud features allow you to monitor your network from anywhere, anytime.
High-Speed Wired and Wireless Connectivity
The DIR-810L Wireless AC750 Dual-Band Cloud Router uses the latest high-speed wireless technology to bring you lightning-fast Wi-Fi connections up to 433 Mbps1. Enjoy streaming media, internet phone calls, online gaming and content-rich web surfing throughout your home. In addition, 10/100 Fast Ethernet ports give you solid, dependable wired performance. The built-in Quality of Service (QoS) engine allows you to prioritize important traffic for seamless connection performance.
Dual-Band Wireless for Seamless Performance
The DIR-810L Wireless AC750 Dual-Band Cloud Router features dual-band wireless, allowing you to operate two concurrent, high-speed Wi-Fi bands for ultimate wireless performance. Surf the web, chat, and play online games on the 2.4 GHz band, while simultaneously streaming digital media on the 5 GHz band. What's more, each band can operate as a separate Wi-Fi network, giving you the ability to customize your network according to your connectivity needs.
Stay informed and protected with mydlink™
This router gives you complete control by allowing you to monitor who is connecting to your network, which sites they are visiting and block unwanted visitors. You can monitor your home network remotely through the mydlink™ web portal or by downloading the free mydlink™ app available for your iOS or Android devices.
Easy to Set Up and Use
Get the DIR-810L up and running in no time right from your couch using the QRS (Quick Router Setup) Mobile app on your iOS or Android device. Simply plug in the router, open the app, and follow a few easy steps to get your home network connected without having to touch a computer. You can also set up a secure network with the touch of a button using Wi-Fi Protected Setup. Simply press the WPS button to instantly establish a secure connection to a new device. If you have additional mydlink™ products, you can take advantage of mydlink™ Zero Configuration. Simply connect your mydlink™-enabled device to the DIR-810L and the router will automatically link it to your mydlink™ account with no configuration required.
D-Link DIR-810L - wireless router - 802.11a/b/g/n/ac (draft 2.0) - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft 2.0)
Frequency Band
2.4 GHz / 5 GHz
NAT support, Stateful Packet Inspection (SPI), IPv6 support, VPN passthrough, Wi-Fi Protected Setup (WPS), reset button
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac (draft 2.0)
15.65 cm x 11.32 cm x 5.36 cm
Microsoft Windows XP SP2, Microsoft Windows 7, Apple MacOS X 10.4 or later, Microsoft Windows Vista, Windows 8
United Kingdom
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Encryption Algorithm
WPA, WPA2
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac (draft 2.0) , C-Tick, FCC
Status Indicators
Power, WAN, WPS
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45
Aerial
Aerial
Internal
External power adapter
1 x network cable
United Kingdom
15.65 cm
11.32 cm
5.36 cm
10 - 95% (non-condensing)
Scroll to top
