BT.com
Wishlist
D-Link DES-1018P (16-Port) Unmanaged Desktop PoE Network Switch
Delivery
Standard Due date unavailable
The D-Link DES-1018P/DES-1018MP 18-Port Fast Ethernet PoE Switches with 2 Gigabit Uplink Ports enables users to easily connect and supply power to PoE-capable devices such as wireless access points (APs), network cameras and IP phones. They can also connect other Ethernet devices like computers, printers and network attached storage (NAS) to fit into any type of network application.
D-Link DES 1018P 18-Port Fast Ethernet PoE Switch with 2 Gigabit Uplink Ports - switch - 16 ports - unmanaged
Switch - 16 ports - unmanaged
Enclosure Type
1U
Ports
8 x 10/100 (PoE) + 8 x 10/100 + 2 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE
PoE Budget
80 W
Performance
Switching capacity: 7.2 Gbps , Forwarding performance (64-byte packet size): 5.36 Mpps
MAC Address Table Size
8K entries
Flow control, power over Ethernet (PoE), auto-uplink (auto MDI/MDI-X), store and forward, 384KB packet buffer, Energy Efficient Ethernet
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3af, IEEE 802.3x, IEEE 802.3az
28 cm x 21 cm x 4.4 cm
1.78 kg
Enclosure Type
Desktop 1U
Ports
PoE
PoE Budget
80 W
Performance
8K entries
Status Indicators
Port transmission speed, power, link/activity
8 x 100Base-TX RJ-45 PoE - 15.4 W , 8 x 100Base-TX RJ-45 , 2 x 1000Base-X RJ-45 , 2 x 1000Base-T SFP
Internal power supply
102.6 Watt
MTBF
395,864 hours
FCC Class A certified, VCCI, C-Tick, BSMI, cUL, CB, CCC, RoHS, LVD
28 cm
21 cm
4.4 cm
1.78 kg
0 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Accessories
£3.79
£13.50
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.40
£52.66
Scroll to top
