Click to visit BT.com
BT.com
Wishlist
D-Link DEM-311GT 1-Port Mini GBIC SX Multi Mode Fiber Tra
Quicklinx: 2NG0WS00
Mfr#: DEM-311GT
Type: Transceiver
Stock Status: Clearance
Express delivery Order within the next 19 hours for delivery on Thursday
£38.40
This transceiver uses the industry-standard Small form Pluggable (SFP) package. It slides into the mini-GBIC slot of the Gigabit device. Like all D-Link mini-GBIC transceivers, it is hot-swappable: you can remove or replace the transceiver with the system powered on, which allows modules to be added or swapped without interrupting the network.
D-Link DEM 311GT - SFP (mini-GBIC) transceiver module - Gigabit Ethernet
SFP (mini-GBIC) transceiver module - LC multi-mode
Plug-in module
Cabling Type
1000Base-SX
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
Gigabit Ethernet
Max Transfer Distance
550 m
D-Link DES-3028, 3052, DWS-3024; DES 12XX, 30XX, 3250, 3350, 35XX; DGS 1024, 12XX, 3100, 32XX, 33XX; L2+ Gigabit Wireless Switch; Web Smart DES-1228, 1252, DGS-1216, 1224, 1248; xStack DES-3526, 3528, 3552, 3828, 3852, DGS-3426, 3427, 3450, 3612, 3627, 3650, DXS-3326, 3350
Plug-in module
Wired
Cabling Type
1000Base-SX
Gigabit Ethernet
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
550 m
1 x Ethernet 1000Base-SX - LC multi-mode x 2
Compatible Slots
1 x SFP (mini-GBIC)
D-Link DES-3028P, DES-3052P, DWS-3024L , D-Link DES 1210, 1226G, 3010G, 3028, 3052, 3250TG, 3350SR, 3526, 3550 , D-Link DGS 1024T, 1216T, 1224T, 1248T, 3100-24, 3100-24P, 3100-24TG, 3100-48, 3100-48P, 3200-10, 3200-16, 3224TGR, 3312SR, 3324SR, 3324SRi , D-Link L2+ Gigabit Wireless Switch DWS-3024 , D-Link Web Smart DES-1228, DES-1252, DGS-1216T, DGS-1224T, DGS-1248T , D-Link xStack DES-3526, DES-3528, DES-3528P, DES-3552, DES-3828, DES-3828DC, DES-3828P, DES-3852, DGS-3426, DGS-3426P, DGS-3427, DGS-3450, DGS-3612G, DGS-3627, DGS-3627G, DGS-3650, DXS-3326GSR, DXS-3350SR
D-Link DEM-311GT 1-Port Mini GBIC SX Multi Mode Fiber Tra Bundle deal on D-Link DEM-311GT 1-Port Mini GBIC SX Multi Mode Fiber Tra
Including:
Intenso 32GB Rainbow Transparent USB Flash Drive Intenso 32GB Rainbow Transparent USB Flash Drive worth £5.48 | in stock
£42.49
saving £1.39
Type: Transceiver
Brand: D-Link
Price Range Inc VAT: 0 - 50
