BT.com
Wishlist
D-Link DCS-800L EyeOn Baby Monitor Junior
Delivery
Standard Due date unavailable
Keep an eye on your little one with the DCS-800L EyeOn Baby Monitor Junior. This portable camera transforms your mobile device into a versatile, yet easy to use baby monitor. Connect to the camera wirelessly or over the Internet so you can check on your infant no matter where you are. It includes a wide array of features to help you care for your child, including night vision, motion and sound detection. It can even play gentle lullabies to help ease your baby to sleep!
The EyeOn Baby Monitor Junior is specially designed to make it easy for you to care for your baby. Its versatile all-day monitoring turns on night vision automatically when it gets dark, giving you a clear picture day or night so you can keep an eye on things anytime. It's perfect for use in the home, or even when you're away; it's mydlink-enabled, which means that you can check on your baby remotely and securely over the Internet.
The EyeOn Baby Monitor Junior can send you notifications you when your baby needs your attention. It can detect movements and sounds, such as baby crying, and alert you immediately. Not only can you see and hear your infant, but you can also comfort them with the sound of your voice through two-way audio (2-way audio is half-duplex).
You can take the EyeOn Baby Monitor Junior with you when traveling with your child, even when there is no available Internet connection. Just connect your mobile device to the EyeOn Baby Monitor Junior' wireless network for instant local monitoring, making it perfect for family holidays or just visiting friends. You can even connect it to an external USB battery (USB battery not included, requires at least 2 A output) for total portability!
Getting started is quick and easy; the free mydlink Baby Monitor app for iOS and Android mobile devices not only guides you step by step through the setup process but also gives you an easy to use interface for all the advanced features of the EyeOn Baby Monitor Junior. Check on your baby at a glance, pinch to zoom in and out with ease or play one of five gentle lullabies to soothe your child. You can even take snapshots and video clips and save them directly to your mobile device!
Just download the free mydlink Baby Monitor app for your smartphone or tablet and you can quickly and easily setup and view your EyeOn Baby Monitor Junior from anywhere with a wireless or 4G LTE/3G connection. You can also log onto the secure mydlink web portal on your computer to keep an eye on what matters most.
D-Link DCS 800L EyeOn Baby Monitor Junior - network surveillance camera
Network surveillance camera - fixed
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
7 cm x 7.5 cm x 10 cm
108 g
Wireless
Camera
Colour - Day&Night
Max Resolution
640 x 480
Optical Sensor Type
CMOS - 1/5" - 640 x 480
Minimum Illumination
0 lux - IR
Focal Length
2.44 mm
Lens Iris
F/2.4
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Voltage
DC 5 V
Motion sensor, date/time stamp, noise detection
Environmental Parameters (operating)
0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
Audio Support
Wireless
7 cm
7.5 cm
10 cm
108 g
Camera
Colour - Day&Night - fixed
Digital Video Format
H.264
Max Digital Video Resolution
640 x 480
Digital Zoom
4
0 lux - IR
Infrared LEDs
Infrared Distance
5 m
Supported Image Formats
JPEG
Image Sensor
640 x 480 CMOS 1/5"
Lens Construction
Focal Length
2.44 mm
Lens Iris
F/2.4
Horizontal Field of View (degree)
57
Vertical Field of View (degree)
42
Network Interface
Network Protocols
DHCP, HTTP, TCP/IP, UDP/IP, ARP, ICMP, HTTPS, UPnP, IPv4
Wall mount kit
C-Tick, IC, FCC
Power Requirements
DC 5 V - 1.5 A
Power adapter - external AC 120/230 V (50/60 Hz) 4.4 Watt
Apple iOS 5.1.1 or later, Android 4.1 (Jelly Bean) or higher
Relative Humidity (operating)
Scroll to top
