BT.com
Wishlist
D-Link DAP-3410 (5.0 GHz) Outdoor Wireless PoE Range Extender
Delivery
Standard Due date unavailable
The DAP-3410 is a Wireless N 5GHz Outdoor Access Point. It can be deployed to expand the coverage and signal strength of an existing wireless network or alternatively used as a low cost alternative to connect networks that are not joined physically by an Ethernet or fiber cable. Within PoE integrated as standard, the DAP-3410 is built to withstand harsh outdoor deployments.
D-Link DAP-3410 - wireless bridge
Wireless bridge
External - outdoor
IEEE 802.11a, IEEE 802.11n
Frequency Band
5 GHz
VLANs supported: 8
Power Over Ethernet (PoE) Supported
PoE
9.6 cm x 4.8 cm x 16.5 cm
350 g
Wireless bridge
Ruggedized Design
Outdoor
9.6 cm
4.8 cm
16.5 cm
350 g
External
Wireless, wired
Data Transfer Rate
300 Mbps
Remote Management Protocol
SNMP 1, SNMP 2, SNMP 3, HTTP, HTTPS
Frequency Band
5 GHz
VLANs supported: 8
Status Indicators
Power, signal strength, LAN
Power over Ethernet (PoE), MAC address filtering, wall mountable
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-Enterprise, WPA2-Enterprise
IEEE 802.3, IEEE 802.3u, IEEE 802.11a, IEEE 802.1x, IEEE 802.11n
Aerial
Antenna
Internal
Gain Level
15 dBi
1 x 100Base-TX (PoE) - RJ-45 , 1 x 100Base-TX - RJ-45
FCC
PoE
-20 °C
60 °C
0 - 90% (non-condensing)
Accessories
£3.74
£13.26
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.13
£51.73
Scroll to top
