BT.com
Wishlist
D-Link AirPlus G 802.11g Wireless LAN USB Adapter
Delivery
Standard Due date unavailable
D-Link, the industry pioneer in wireless networking, introduces the DWL-G122 Wireless USB Adapter, part of the AirPlus G family of 802.11g wireless networking devices.
Using the DWL-G122 Wireless USB Adapter, you can now enable 802.11g wireless connectivity for your PC using the convenience and speed of a USB 2.0 interface.
Featuring the latest in wireless technology, the DWL-G122 delivers incredibly fast performance and industry-wide compatibility.
By adhering to the 802.11g wireless standard, the DWL-G122 is capable of streaming video and transferring large files across a wireless network.
The DWL-G122 Wireless USB Adapter includes an easy-to-use configuration that discovers available wireless networks wherever you go. The utility can also create detailed connectivity profiles to save your most frequently used networks. You can also enable support for WPA and 802.1x, for better data encryption and user authentication.
The DWL-G122 is a Wireless USB 2.0 adapter that installs quickly and easily into any desktop or laptop PC with an available USB port. You can simply plug in the DWL-G122 to enjoy the freedom of wireless networking. When used with other D-Link AirPlus G products in their default configuration, the DWL-G122 automatically discovers and connects to the wireless network.
Like all other D-Link wireless adapters, the DWL-G122 Wireless USB Adapter can be used in peer-to-peer mode (ad-hoc) to directly connect to other 802.11b/g wirelessly enabled computers for direct file sharing, or in client mode (infrastructure) to connect with wireless access points or routers.
Network adapter
External
Interface (Bus) Type
Hi-Speed USB
2.3 cm x 7.5 mm x 0.6 cm
IEEE 802.11b, IEEE 802.11g
Data Transfer Rate
54 Mbps
Frequency Band
2.4 GHz
IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED
2000 / XP
Microsoft Certification
Network adapter
External
Hi-Speed USB
2.3 cm
7.5 mm
0.6 cm
Wireless
Spread Spectrum Method
OFDM, DSSS
Data Transfer Rate
54 Mbps
Line Coding Format
CCK, BPSK, QPSK, OFDM
Frequency Band
2.4 GHz
Max Range Indoors
100 m
Max Range Open Space
400 m
Status Indicators
Link activity, power, link OK
Aerial
Antenna
Internal integrated
Directivity
Omni-directional
1 x Hi-Speed USB - 4 PIN USB Type A
1 x USB extension cable ( external ) - 1.5 m
Encryption Algorithm
128-bit WEP, 64-bit WEP, TKIP, WPA, WPA2
Certified for Windows Vista
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
FCC Class B certified, CE, FCC Part 15
Software Included
Drivers & Utilities
Microsoft Windows 98SE/2000/ME/XP
Customer reviews
Write review Read all The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Why Pay More
Reviewed by oddjob on 22/08/2009
Does exactly what is says on the box. Easy to install (be sure to load the D-Link driver before plug and play gets involved.) Good value for money. Good performance. Picked up my router signal through two 18 inch walls!
5* Great Value
Reviewed by Les on 29/03/2008
Absolutely brilliant piece of kit for the price .... it does exactly what it says on the box.
5* Compact, portable, easy to install and it works!
Reviewed by Anonymous on 11/09/2005
This is a breeze to install. It came bundled with a wireless ADSL modem/router/firewall (DSL-G604T) so I didn't actually pay the full price for it. The accompanying CD installed drivers on WinXP without trouble. It's currently working on a PC that's about 25ft away from the router, with two old walls between, and signal strength is strong to very strong in its present location. Recommended.
5* Works on a Mac!
Reviewed by Rory Hackett on 07/02/2006
This adaptor even works on macs - unlike loads of the competition. This card works perfectly on OSX 10.4 and is a must more cost effective way of getting wireless on an older mac than buying one of those internal airport cards that are about £75 on eBay! I really recommend these adaptors and i've found them to be really reliable so far!
5* Using 2
Reviewed by Regs on 29/06/2006
I have two of these running on 2 PC's in my attic, one gaming machine and one printer sever, data storage desktop. My 604T is on the grouns floor of the house which is a very old terrace, I have great connection and never had any problems with dropped connections at all.
Great piece of kit, I do especially like the USB stands to allow your antenna to be positioned as effectively as possible. Absolute doddle to set up.
5* Good range
Reviewed by James on 16/02/2007
Nice and cheap and has a very good range. Easy to install but easier to use if you just let windows do it for you.
The signal did tend to drop occasionally, but that could be due to many things.
The long USB cord allowed the device to be move around to get the best signal.
4* Easy Peasy
Reviewed by Anonymous on 15/09/2005
Easy to start up and use, connected first time. But I couldn't get the utility programme to run as it said it should in the manual; even after downloading and installing the updated software from DLink. However, it works and that's the main thing.
3* Not Good Range
Reviewed by Gary Pittaway on 10/01/2009
A nice little easy wireless fix but don't be fooled by the 100 metres to 400 metres distance claim. I placed this in a computer 25 metres from the house and the signal was terrible constantly dropping out and losing the network completely.
3* Easy but slow to connect
Reviewed by Anonymous on 27/05/2006
I had no problems with the software at all. Installed software first then added the device - easy.
Only problems I have found is that it seems slow to connect when starting up but this is certainly not the only wireless device to have this trouble. I never have any problems with it after it has made it's first connection...
2* I'd keep looking...
Reviewed by Anonymous on 03/01/2006
Pretty much the cheapest one around, but I guess you get what you pay for! I bought 4,for different computers and have had lots of trouble with them. The software on the CD doesn't appear to do anything apart from crash ocasionally. The card is much more stable if you ignore the instruction to install the software first, just plug it in and let windows find the driver on the CD for itself. When it works it is great, but sometimes won't connect at all. Also had to send one back which stopped working (and BT want to charge me 7.95 +VAT for the privilege!?!?!
Scroll to top
