BT.com
Wishlist
D-Link 8-Port 10BaseT 100BaseTX
£8.08
More than 50 in stock
£8.08
Add to wishlist
Delivery
Standard 3-5 working days
The DES-1008D 8-Port Fast Ethernet Unmanaged Desktop Switch is an 8-port 10/100 Mbps Fast Ethernet switch that allows you to quickly set up a wired network. Connect the DES-1008D to multiple computers together to share files and folders, or connect it to a router to share an Internet connection.
D-Link DES 1008D - switch - 8 ports - unmanaged
Switch - 8 ports - unmanaged
Subtype
Fast Ethernet
Ports
8 x 10/100
MAC Address Table Size
8K entries
Flow control, auto-sensing per device, auto-negotiation, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.3x
AC 120/230 V
19.2 cm x 11.8 cm x 3.2 cm
301 g
Enclosure Type
Desktop
Subtype
Fast Ethernet
Ports
8 x 10/100
8K entries
RAM
256 KB
Status Indicators
Collision status, port transmission speed, port duplex mode, power, link/activity
8 x 100Base-TX RJ-45
External power adapter
AC 120/230 V
2 Watt
FCC Class B certified, VCCI Class A ITE
19.2 cm
11.8 cm
3.2 cm
301 g
50 °C
10 - 90%
Accessories
£3.79
£13.50
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.40
£52.66
Scroll to top
