BT.com
Wishlist
D-Link 60 Watt Redundant Power Supply
D-Link 60 Watt Redundant Power...
Free delivery
£203.48
Free delivery
£203.48
Add to wishlist
Delivery
Standard Due date unavailable
This RPS is equipped with an integrated detection circuit that continuously monitors the switching device's internal power supply. In the event of a power interruption, the redundant power supply is immediately triggered so that the LAN switch and its connected devices can continue providing service. This results in a more reliable network infrastructure and protects the network from a single failure of a network device power supply.
D-Link DPS-200 - power supply - 60 Watt
Power supply
0.8 kg
Output Voltage
12 V
Power Capacity
60 Watt
12.7 cm x 7.6 cm x 3.7 cm
DES 3350SR, 3526, 3550; DGS 3100-24, 3100-24TG, 3312SR; xStack DES-3526, DES-3528, DES-3552, DES-3828, DXS-3350SR
Power supply
Input Voltage Range
AC 100 - 240 V
Input Voltage Range (Adjustable)
AC 90 - 264 V
Frequency Required
47 - 63 Hz
Output Voltage
12 V
Power Capacity
60 Watt
FCC Class B certified, CSA, TUV, CISPR 22 Class B, cUL, EN 60950, EN55022, UL 60950
50 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
80 °C
20 - 80%
Humidity Range Storage
10 - 90%
12.7 cm
7.6 cm
3.7 cm
0.8 kg
D-Link DES 3350SR, 3526, 3550 , D-Link DGS 3100-24, 3100-24TG, 3312SR , D-Link xStack DES-3526, DES-3528, DES-3552, DES-3828, DXS-3350SR
Scroll to top
