BT.com
Wishlist
D-Link 4G LTE USB Adapter
Delivery
Standard Due date unavailable
The DWM-221 4G LTE USB Adapter is a portable travel modem that allows you to stay connected to the Internet wherever you are with fast downlink and uplink data rates, as well as low latency for a fast and responsive connection when you're on the road.
D-Link DWM-221 - wireless cellular modem - 4G LTE
Wireless cellular modem - USB 2.0
External
Max Transfer Rate
100 Mbps
Cellular Protocol
GSM, GPRS, UMTS, EDGE, WCDMA, HSPA, HSPA+, LTE, DC-HSPA+
Apple MacOS X 10.5 or later, Microsoft Windows Vista / XP / 7 / 8
9.9 cm x 3.25 cm x 1.1 cm
35 g
External
Modem
Bus
USB 2.0
Wireless
Max Transfer Rate
100 Mbps
Cellular Protocol
Antenna
Internal
Antenna Qty
1
Supported Flash Memory Cards
microSD
SIM Card Supported
Regular (mini-SIM) x 1
WHQL, FCC, RoHS
9.9 cm
3.25 cm
1.1 cm
35 g
-10 °C
45 °C
Scroll to top
