BT.com
Wishlist
D-Link 4G LTE Router
£174.75
29 in stock
£174.75
Add to wishlist
Delivery
Standard 1-3 working days
D-Link's DWR-921 4G LTE Router allows you to access and share your 4G LTE or 3G mobile broadband connections. Once connected, you can transfer data, stream media, and send SMS messages. Simply insert your SIM/USIM card and share your 4G LTE or 3G Internet connection through a secure wireless network or any of the four Ethernet ports. The DWR-921 4G LTE Router is designed with constant connection in mind. Dual-band 4G LTE and 3G support allows automatic 3G connection if or when the 4G LTE signal strength becomes low, whereas the additional xDSL/FTTH Ethernet WAN option gives fail-safe connectivity if either your fixed line or mobile broadband fails.
D-Link DWR-921 4G LTE Router - wireless router - WWAN - 802.11b/g/n - desktop
Wireless router - wireless cellular modem - 4-port switch (integrated)
Enclosure Type
Desktop
Cellular Protocol
UMTS, HSDPA, HSUPA, LTE
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
150 Mbps
Network / Transport Protocol
PPTP, L2TP, IPSec
NAT support, Stateful Packet Inspection (SPI), VPN passthrough, IPSec passthrough
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n
19 cm x 11.15 cm x 2.35 cm
0.5 kg
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
150 Mbps
PPTP, L2TP, IPSec
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
Status Indicators
WLAN, WAN, LAN, 3G, SMS
Communications
Wireless cellular modem
Cellular Protocol
Max Transfer Rate
100 Mbps
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45
Expansion Slots
1 (total) / 1 (free) x SIM
Aerial
Aerial
External detachable
Antenna Qty
2
External power adapter
19 cm
11.15 cm
2.35 cm
0.5 kg
10 - 90% (non-condensing)
Accessories
£5.11
£3.88
£12.50
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.92
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.69
£56.55
Scroll to top
