BT.com
Wishlist
D-Link 20 10/100/1000 Base-T port Unified Switch
Delivery
Standard Due date unavailable
The DWS-3160 Series is D-Link's latest unified wired/wireless Gigabit Layer 2+ managed switch. Designed to be the ideal mobility solution for medium-sized and large enterprises and service providers, the DWS-3160 empowers administrators to exercise total control over their wireless networks by centralizing all aspects of provisioning and management.
D-Link DWS-3160 - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
20 x 10/100/1000 + 4 x combo Gigabit SFP
Performance
Switching capacity: 48 Gbps
MAC Address Table Size
8K entries
Jumbo Frame Support
Routing Protocol
RIP, static IP routing
Remote Management Protocol
SNMP 1, RMON, Telnet, SNMP 3, SNMP 2c, TFTP, SSH, CLI
BOOTP support, VLAN support, IGMP snooping, port mirroring, IPv6 support, sFlow, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Virtual Route Redundancy Protocol (VRRP) support, Multiple Spanning Tree Protocol (MSTP) support, Quality of Service (QoS), DHCP server, MLD snooping, Network Access Protection (NAP), bandwidth control, LLDP support, DHCP relay, Link Aggregation Control Protocol (LACP), Traffic Control, DHCP client, Dynamic VLAN Support (GVRP)
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1v, IEEE 802.1ab (LLDP)
44 cm x 21 cm x 4.4 cm
2.6 kg
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
8K entries
Jumbo Frame Support
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+
20 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 4 x SFP (mini-GBIC) , 1 x management RJ-45
Internal power supply
MTBF
561,829 hours
FCC Class A certified, UL, VCCI, C-Tick, cUL, ICES-003, CB
44 cm
21 cm
4.4 cm
2.6 kg
50 °C
10 - 90%
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90%
Scroll to top
