BT.com
Wishlist
D-Link 140 Watt RPSU Redundant Power Supply Unit
D-Link 140 Watt RPSU Redundant...
£345.03
£345.03
Add to wishlist
Delivery
Standard Due date unavailable
This RPS is equipped with an integrated detection circuit that continuously monitors the switching device's internal power supply. In the event of a power interruption, the redundant power supply is immediately triggered so that the LAN switch and its connected devices can continue providing service. This results in a more reliable network infrastructure and protects the network from a single failure of a network device power supply. It is suitable for DGS-3427, DGS-3450, DGS-3300 Series, DXS-3300 Series, DGS-3600 Series, DGS-3048, DGS-3100-48.
D-Link DPS-500 - power supply - 160 Watt
Power supply
1.5 kg
Input Voltage
AC 115/230 V
Output Voltage
+5, +12 V
Power Capacity
160 Watt
19.5 cm x 19.6 cm x 5 cm
DGS 3100-48, 3324SR, 3324SRi; xStack DGS-3426, DGS-3427, DGS-3450, DGS-3612G, DGS-3627, DGS-3627G, DGS-3650, DXS-3326GSR, DXS-3350SR
Power supply
Input Voltage
AC 115/230 V
Input Voltage Range
AC 90 - 264 V
Frequency Required
47 - 63 Hz
Output Voltage
+5, +12 V
Power Capacity
160 Watt
FCC Class B certified, CSA, cUL, EN 60950, UL 60950
50 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
80 °C
20 - 80%
Humidity Range Storage
10 - 90%
19.5 cm
19.6 cm
5 cm
1.5 kg
D-Link DGS 3100-48, 3324SR, 3324SRi , D-Link xStack DGS-3426, DGS-3427, DGS-3450, DGS-3612G, DGS-3627, DGS-3627G, DGS-3650, DXS-3326GSR, DXS-3350SR
Scroll to top
