BT.com
Wishlist
D-Link 1-port 10GbE XFP Fiber Transceiver (300m)
Delivery
Standard Due date unavailable
Designed to support distances up to 300 meters, the DEM-421XT is a high performance 850nm Multi-Mode XFP transceiver. Supporting Full-duplex, 10Gigabit speeds on Multi-Mode fiber cables, the DEM-421XT is 802.3ae 10GBASE-SR compliant and supports Full-duplex 802.3x Flow control. The DEM-421XT provides the necessary signal amplification for data to be transmitted to the network cable from the port, and vice versa.
The DEM-421XT is hot swappable. You can remove or replace the transceiver with the system powered on. This permits transceivers to be added or swapped without interrupting network systems.
D-Link DEM 421XT - XFP transceiver module - 10 GigE
XFP transceiver module - LC multi-mode
Plug-in module
Cabling Type
10GBase-SR
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
10 GigE
Max Transfer Distance
300 m
D-Link DEM-420X; xStack DXS-3326GSR
Plug-in module
Wired
Cabling Type
10GBase-SR
10 GigE
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
300 m
Full duplex capability
IEEE 802.3x, IEEE 802.3ae
1 x Ethernet 10GBase-SR - LC multi-mode x 2
Compatible Slots
1 x XFP
D-Link DEM-420X , D-Link xStack DXS-3326GSR
Accessories
£3.68
£12.66
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£7.72
£48.96
Scroll to top
