BT.com
Wishlist
Cyberpower VALUE 600EILCD Value Series Uninterruptible Power Supply, 360W/600VA
Cyberpower VALUE 600EILCD Value...
£73.99
10 in stock
£73.99
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Tuesday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Value Series UPS with Automatic Voltage Regulator (AVR) is the best solution for SOHO to supply a clean and stable power. Value series UPS is compatible with many different operating systems. Value Series UPS is the most cost-economy and reliable UPS to bring you the best power supplies.
CyberPower Value 600E - UPS - 360 Watt - 600 VA
UPS - external
4.8 kg
Output Voltage
AC 230 V ± 5%
Power Capacity
360 Watt / 600 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
3 x power IEC 60320
Lead Acid 7 Ah
Battery Form Factor
Internal
Batteries Qty
1
Run Time (Up To)
1.5 min at full load
RS-232, USB
Apple MacOS, Linux, Microsoft Windows 2000 Professional, Microsoft Windows 98/ME, Microsoft Windows Vista / XP / 7, Microsoft Windows 2003, Microsoft Windows Server 2008
10 cm x 30 cm x 14 cm
UPS - external
Battery Enclosure Type
Internal
Frequency Provided
50/60 Hz
Frequency Required
50 - 60 Hz
Input Connectors
3 x power IEC 60320
Output Voltage
AC 230 V ± 5% - 50/60 Hz
Power Capacity
360 Watt / 600 VA
Dataline Surge Protection
Network/phone line - RJ-45/RJ-11
Output Waveform
Stepped approximation to a sinewave
Surge Suppression
Circuit Protection
Fuse
Quantity
1
Lead Acid
Voltage Provided
12 V
7 Ah
Run Time (Up To)
1.5 min at full load , 9.5 min at half load
Recharge Time
8 hours
Switchover Time
8 ms
Remote Management Interface
RS-232, USB
1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x management (USB) - 4 pin USB Type B
Power cable - external , USB cable - external
Equipment Protection Value
50000 Euros
Audible alarm, LCD display, Automatic Voltage Regulation (AVR), LED indicators, overload protection
PCT, ISO 14001, RoHS, ISO 9001:2000
Software Included
PowerPanel Personal Edition
10 cm
30 cm
14 cm
4.8 kg
Scroll to top
