BT.com
Wishlist
CyberPower Professional Rack Mount LCD Series PR6000ELCDRTXL5U UPS 4.5 kW 6000 VA
CyberPower Professional Rack Mount...
£2,107.06
£2,107.06
Add to wishlist
Delivery
Standard Due date unavailable
The professional rack mount LCD series provides an advanced level of power protection to support mission-critical servers, telecom equipment, VOIP and Internet working hardware. This series has both a pure sine wave waveform and full Automatic Voltage Regulation (AVR) technology, which delivers a consistent and clean AC signal that protects connected equipment and prevents costly business interruptions. The multifunction LCD readout provides ready access to power/battery condition vitals. The patented GreenPower UPS advanced circuitry reduces UPS energy costs. You will find less heat dissipation as well.
CyberPower Professional Rack Mount LCD Series PR6000ELCDRTXL5U - UPS - 4.5 kW - 6000 VA
UPS - external
Rack Size
5U
103.5 kg
Input Voltage
AC 150-300 V
Output Voltage
AC 230 V
Power Capacity
4.5 kW / 6000 VA
Input Connectors
Hardwire 3-wire
Output connectors
8 x power IEC 60320 C13 , 2 x power IEC 60320 C19 , 1 x hardwire 3-wire
Lead Acid 9 Ah
Battery Form Factor
Internal
Run Time (Up To)
10 min at full load
RS-232, USB
Tower stand, rack mounting rails, rack mounting ears
43.3 cm x 64.5 cm x 22 cm
UPS - external
Battery Enclosure Type
Internal
Height (Rack Units)
5U
UPS Technology
Line interactive
Input Voltage
AC 150-300 V
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz
Input Connectors
Hardwire 3-wire
Output Voltage
AC 230 V 50/60 Hz
Power Capacity
4.5 kW / 6000 VA
Dataline Surge Protection
Network/phone line - RJ-45/RJ-11 - 1 input line / 1 output line
Output Waveform
Sinewave
Surge Suppression
Circuit Protection
Circuit breaker
Lead Acid
Voltage Provided
12 V
9 Ah
Run Time (Up To)
10 min at full load , 28 min at half load
Recharge Time
4 hours
Remote Management Interface
RS-232, USB
1 x USB - 4 pin USB Type B , 2 x RS-232 - 9 pin D-Sub (DB-9)
Phone cable - external , USB cable - external , Emergency power off cable - external , Serial cable - external
Rack Mounting Kit
Included
Audible alarm, emergency power off, LCD display, Automatic Voltage Regulation (AVR), GreenPower UPS Technology, overload protection, hot-swappable batteries, Energy-Saving Outlets
Software Included
PowerPanel Business Edition
43.3 cm
64.5 cm
22 cm
103.5 kg
Scroll to top
