BT.com
Wishlist
Cyberpower Pro 1500VA 2U Rack UPS
£554.86
£554.86
Add to wishlist
Delivery
Standard Due date unavailable
The Professional Rackmount PR1500ELCDRT2U UPS with LCD readout and pure sine wave output is Active PFC compatible, safeguarding mission-critical servers, telecom equipment, VoIP and internetworking hardware that requires seamless connection and advanced power protection. Featuring Automatic Voltage Regulation (AVR) technology that helps to stabilize AC voltage and to provide protection to connected equipment.This UPS system is designed with patented GreenPower UPS™ bypass circuitry that improves the operating efficiency so that users can enjoy significant cost savings by reducing energy consumption and waste heat generated.
The PR1500ELCDRT2U comes with a capacity of 1500VA/1000Watts and eight (8) IEC C13 receptacles, including two (2) for critical loads management. It has four (4) hot-swappable, user-replaceable 12V/7Ah batteries. The multifunction LCD panel with control switch allows users not only to easily check the real-time power/battery status at a single push-of-a-button, but to quickly configure settings within a few touches. RJ11/RJ45 (One-in/One-out) port is included for the protection of phone and network line. The EMI/RFI filters increase the tolerance of noises and load interferences so that improve the picture and sound quality in audio/video systems. The unit offers one (1) HID USB and one (1) Serial connectivity port with PC and one (1) Emergency Power Off (EPO) port for the capability to immediately power down entire installed equipment from a single access point.
The PR1500ELCDRT2U features remote network management capabilities which include the PowerPanel® Business Edition software, an optional SNMP/ HTTP remote management card, and an optional ENVIROSENSOR. These management tools enable administrators to perform various operations including remote management, real-time monitoring, UPS configuration, and scheduled server/workstations shutdowns. All Smart App UPS systems and Remote Management Card have achieved the status of Cisco EnergyWise certified, better supporting other EnergyWise-enabled entities and be easily monitored and controlled to achieve the best energy performance under the EnergyWise operation framework.
For as long as you own this product, CyberPower will cover up to $100,000 of properly connected equipment if it's ever damaged by a surge, including surges due to lightning strikes.
CyberPower Professional Rack Mount LCD Series PR1500ELCDRT2U - UPS - 1 kW - 1500 VA
UPS - rack-mountable
Output Connectors
8 x power
Rack Size
2U
27 kg
Output Voltage
AC 230 V ± 5%
Power Capacity
1 kW / 1500 VA
Input Connectors
1 x power
Output connectors
8 x power
Lead Acid - 7 Ah
Batteries Qty
4
RS-232, USB
43.3 cm x 38.8 cm x 8.8 cm
Height (Rack Units)
2U
Output Connectors
8 x power
Input Voltage Range
AC 160 - 290 V
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz
Input Connectors
1 x power
8 x power
Output Voltage
AC 230 V ± 5% - 50/60 Hz
Power Capacity
1 kW / 1500 VA
Dataline Surge Protection
Network/phone line - RJ-45/RJ-11
Output Waveform
Sinewave
Surge Suppression
Circuit Protection
Circuit breaker
Quantity
4
Lead Acid
7 Ah
Recharge Time
8 hours
Remote Management Interface
RS-232, USB
2 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x management (USB) - 4 pin USB Type B , 1 x management (USB) - RJ-11
Expansion Slots
1 (total) / 1 (free) x Expansion Slot
USB cable - external , Serial cable - external , 4 x power cable - external , Phone cable - external
Rack Mounting Kit
Included
Audible alarm, LCD display, Automatic Voltage Regulation (AVR), GreenPower UPS Technology, overload protection
Software Included
PowerPanel Business Edition
43.3 cm
38.8 cm
8.8 cm
27 kg
Scroll to top
