BT.com
Wishlist
Cyberpower Maintenance By-Pass IEC Outlet. Compatible with OL 1-3KVA
Delivery
Standard Due date unavailable
CyberPower Maintenance Bypass PDU (MBP) allows administrators to easily switch to utility power during UPS maintenance without interrupting the operation of critical devices. Through the manual bypass switch and quick transfer time, administrators can ensure a consistent and seamless connection for connected equipment. The standard IEC connectors support most IT devices and UPSs of maximum ratings up to 3kVA.
With its flexible configuration, the MBP can be easily attached to backup UPS either in horizontal or vertical deployment to make the most of users’ work space!
CyberPower MBP20HVIEC6 - power distribution unit
Power distribution unit - rack-mountable
Rack Size
19" - 1U
1.3 kg
Input Voltage
AC 200-240 V
Input Connectors
Power IEC 60320 C19, power IEC 60320 C20
Output connectors
6 x power IEC 60320 C13 , 1 x power IEC 60320 C19
43.3 cm x 7.6 cm x 5.1 cm
Height (Rack Units)
1U
Rack Size
19"
Input Voltage
AC 200-240 V
Input Connectors
Max Electric Current
16 A
Vertical orientation, horizontal orientation, built-in maintenance bypass
0 - 90%
43.3 cm
7.6 cm
5.1 cm
1.3 kg
Scroll to top
