BT.com
Wishlist
CyberPower BPE48V75ART2U Battery Enclosure Lead Acid 9 Ah
CyberPower BPE48V75ART2U Battery...
£408.91
£408.91
Add to wishlist
Delivery
Standard Due date unavailable
These 2U packs esthetically match the UPS, and can similarly be rack or tower mounted. The heavy gauge power cord is adapted with plug-n-play DC connectors for easy installation. The all metal enclosure safely houses the 8 (eight) 12V 9Ah batteries which are connected via 3 strings of 4 in series.
CyberPower BPE48V75ART2U - battery enclosure - Lead Acid - 9 Ah
Battery enclosure - external
Rack Size
2U
35 kg
Lead Acid - 9 Ah
Battery Form Factor
Plug-in module
Batteries Qty
8
43.3 cm x 48 cm x 8.8 cm
Professional Rack Mount LCD Series PR1000ELCDRTXL2U, PR1500ELCDRTXL2U, PR2200ELCDRTXL2U, PR3000ELCDRT2U
Battery Enclosure Type
Plug-in module
Height (Rack Units)
2U
Circuit Protection
Fuse
Quantity
8
Lead Acid
Voltage Provided
12 V
9 Ah
Recharge Time
8 hours
Rack Mounting Kit
Included
RoHS
0 - 95%
43.3 cm
48 cm
8.8 cm
35 kg
CyberPower Professional Rack Mount LCD Series PR1000ELCDRTXL2U, PR1500ELCDRTXL2U, PR2200ELCDRTXL2U, PR3000ELCDRT2U
Scroll to top
