BT.com
Wishlist
Cyberpower Basic Series PDU20BHVIEC12RA Power Distribution Unit
Delivery
Standard Due date unavailable
The CyberPower 12-outlet rack mount basic power distribution unit provides 200V/230V 20A output. It distributes power to 12 IEC-320 receptacles from a single IEC-320 C20 plug, with unfiltered electrical pass-through. Designed for datacenters and other electrically demanding applications, this unit has a rugged, industrial-grade metal housing and a 10-foot AC power cord.
CyberPower Basic Series PDU20BHVIEC12RA - power distribution unit
Power distribution unit - rack-mountable
Output Connectors
12 x power IEC 60320 C13, power IEC 60320 C19
Rack Size
1U
0.9 kg
Input Voltage
AC 200/230 V
Output Voltage
AC 200/230 V
Input Connectors
1 x power IEC 60320 C20
Output connectors
10 x power IEC 60320 C13 , 2 x power IEC 60320 C19
44.5 cm x 3.8 cm x 4.5 cm
Height (Rack Units)
1U
Output Connectors
Input Voltage
AC 200/230 V
Input Voltage Range
AC 200 - 230 V
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 200/230 V
Max Electric Current
20 A
Circuit Protection
Circuit breaker
Power cable - 3 m
Rack Mounting Kit
Included
Rugged, overload protection, vertical orientation
CSA C22.2, RoHS, ETL, UL 60950-1
Limited warranty - lifetime
0 - 95%
44.5 cm
3.8 cm
4.5 cm
0.9 kg
Scroll to top
