BT.com
Wishlist
Cyberpower 800EILCD Value Series Uninteruptible Power Supply, 480W/800V
Cyberpower 800EILCD Value Series...
£94.80
10 in stock
£94.80
Add to wishlist
Delivery
Standard 3-5 working days
Value Series UPS with Automatic Voltage Regulator (AVR) is the best solution for SOHO to supply a clean and stable power. Value series UPS is compatible with many different operating systems, including Microsoft Windows 98/Me/2000/NT/XP. PowerPanel Personal Edition management software included for USB Port shows versatility of a UPS, like power voltage, scheduled shutdown, and remaining battery capacity, remaining battery runtime, battery status, etc. Value Series UPS is the most cost-economy and reliable UPS to bring you the best power supplies.
CyberPower Value 800E - UPS - 480 Watt - 800 VA
UPS - external
5.4 kg
Output Voltage
AC 230 V ± 5%
Power Capacity
480 Watt / 800 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
3 x power IEC 60320
Lead Acid 8.5 Ah
Battery Form Factor
Internal
Batteries Qty
1
Run Time (Up To)
1.5 min at full load
RS-232, USB
Apple MacOS, Linux, Microsoft Windows 2000 Professional, Microsoft Windows 98/ME, Microsoft Windows Vista / XP / 7, Microsoft Windows 2003, Microsoft Windows Server 2008
10 cm x 30 cm x 14 cm
UPS - external
Battery Enclosure Type
Internal
Frequency Provided
50/60 Hz
Frequency Required
50 - 60 Hz
Input Connectors
3 x power IEC 60320
Output Voltage
AC 230 V ± 5% - 50/60 Hz
Power Capacity
480 Watt / 800 VA
Dataline Surge Protection
Network/phone line - RJ-45/RJ-11
Output Waveform
Stepped approximation to a sinewave
Surge Suppression
Circuit Protection
Fuse
Quantity
1
Lead Acid
Voltage Provided
12 V
8.5 Ah
Run Time (Up To)
1.5 min at full load , 8.5 min at half load
Recharge Time
8 hours
Switchover Time
8 ms
Remote Management Interface
RS-232, USB
1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x management (USB) - 4 pin USB Type B
Power cable - external , USB cable - external
Equipment Protection Value
50000 Euros
Audible alarm, LCD display, Automatic Voltage Regulation (AVR), LED indicators, overload protection
PCT, ISO 14001, RoHS, ISO 9001:2000
Software Included
10 cm
30 cm
14 cm
5.4 kg
Scroll to top
