BT.com
Wishlist
Cubify 3D Systems Cube Pro Desktop 3D Printer - 2 Print Heads
Cubify 3D Systems Cube Pro Desktop...
£1,759.56
£1,759.56
Add to wishlist
Delivery
Standard 1-3 working days
The CubePro features large build platform with ultra high-resolution. With this hobbyist printer with ultra high-resolution settings professional quality printing is so large and easy.
Controlled print environment
A controlled process environment ensures improved accuracy and reliability of print for effortless, professional quality every time for your largest ABS plastic prints. Automated settings ensure home-safe printing in your mancave, on your workbench and at your desktop.
Print big, print accurate
The CubePro features the largest-in-class build platform with ultra high-resolution. With prints 2.5 times larger than any other desktop prosumer and hobbyist printer (11.2" x 10.6" x 9.06" or 285.4mm x 270.4mm x 230mm) with ultra high-resolution settings of 70-micron thin print layers, professional quality printing has never been so large or easy.
New materials, limitless possibilities
Printing with complexity has never been easier. Break beyond boundaries set by unachievable overhangs and the laws of gravity, and enter the possibilities of intricate patters, degrees of freedom and suspension in space. Create functional prototype models or make end-use parts for your engineering applications.
Strong, fast & long-lasting
Guaranteed faster, more accurate prints with stabilized print mechanics and easy feed cartridges for prolonged material life.
Triple color + three materials = thousands of options
Get more expressive with 3D printing in up to 3 simultaneous colors with 3 material options. Select from over 24 vibrant colors for more unique combinations.
Connect better to experience better
Connect conveniently with an easy to use color touchscreen display and WiFi capability
Windows requirements: Cube software runs on 32 and 64-bit Operating Systems: -
-Windows XP Professional or Home Edition with Service Pack 3 -Windows 7 -Windows 8 -Windows 7 is required for ad-hoc WiFi Print Job submission - if not already installed, the Cube Software installer will automatically install the Microsoft .NET 4.0 Framework
Mac OSX requirements: Cube software runs on Mac OSX 10.8
Minimum hardware requirements: -Processor: Multi-core processor - 2GHz or faster per core -System RAM: 2 GB -Screen Resolution: 1024x768
Key Features
Print technology: Plastic Jet Printing (PJP)
Print Jets: Dual jets
Maximum creation size: 6 x 6 x 6" / 15.2 x 15.2 x 15.2 cm
Materials: Tough recyclable ABS plastic or compostable PLA plastic
Layer Thickness: 70 microns, fast mode: 200 microns
Supports: Fully Automated, easy to peel off
Cartridge: Each cartridge prints 13 to 14 mid-sized creations
Dimensions: W x D x H (With Cartridge) 335 x 338 x 280 mm
Weight (With Cartridge) 7.7 Kg
3D Systems CubePro Duo - 3D printer
Printer Type
3D printer - FDM - 3 colour printing
37.4 kg
Max Build Size
270.4 x 242.9 x 230 mm
Build Speed
15 mm3/sec
Min Layer Thickness
70 µm
USB, Wi-Fi
Build Materials Supported
Polylactide (PLA), acrylonitrile butadiene styrene (ABS)
AC 120/230 V
Microsoft Windows 7, Microsoft Windows XP Professional SP3, Microsoft Windows XP Home Edition SP3, Windows 8, Apple MacOS X 10.8
57.8 cm x 57.8 cm x 59.1 cm
Printer Type
3D printer
Fused Deposition Modeling (FDM)
Multicolour Print
Yes (3 colour printing)
Printer
Build Speed
15 mm3/sec
Built-in Devices
Status LCD, touch screen
Wireless
USB, Wi-Fi
Min Layer Thickness
70 µm
Input File Formats Supported
STL
Media Handling
Max Build Size
1 x USB - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
Power supply - internal
AC 120/230 V
System Requirements Details
2 GHz - RAM 2 GB
57.8 cm
57.8 cm
59.1 cm
37.4 kg
Scroll to top
