BT.com
Wishlist
Crucial MX200 500GB SATA 6Gb/s Solid State Drive
Delivery
Standard Due date unavailable
Make your computer faster and more efficient with the Crucial MX200 SSD, which delivers the industry’s best balance of performance, endurance, and efficiency. Leveraging leading specs on all fronts, along with the Dynamic Write Acceleration technology, the Crucial MX200 is loaded with innovative features and immediately increases your system’s performance. With sequential reads up to 555 MB/s and an endurance rating that’s up to 5 times greater than a typical client SSD, the Crucial MX200 is engineered to never let up.
Crucial MX200 - solid state drive - 500 GB - SATA 6Gb/s
Solid state drive - internal
500 GB
Hardware Encryption
NAND Flash Memory Type
Multi-level cell (MLC)
M.2 2280
SATA 6Gb/s
Data Transfer Rate
600 MBps
TRIM support, Error Correction Code (ECC), Power Loss support, Adaptive Thermal Protection, Microsoft eDrive compatible, Redundant Array of Independent NAND, Active Garbage Collection, Extreme Energy Efficiency technology, Data Path Protection, dynamic write acceleration, Exclusive Data Defense, S.M.A.R.T., 256-bit AES, IEEE 1667
22 mm x 80 mm
Microsoft Certification
Compatible with Windows 7
3 years warranty
500 GB
Hardware Encryption
M.2 2280
SATA 6Gb/s
22 mm
80 mm
Performance
SSD Endurance
160 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
555 MBps (read) / 500 MBps (write)
4KB Random Read
100000 IOPS
4KB Random Write
87000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - M.2 Card
Compatible Bay
M.2 2280
UL, TUV, VCCI, C-Tick, BSMI, IC, FCC, RoHS, KCC, WEEE
Limited warranty - 3 years
70 °C
Scroll to top
