Click to visit BT.com
BT.com
Wishlist
Crucial 8GB (2 x 4GB) Ballistix Sport DDR3 1600MHz CL9 1.5v 240pin
Quicklinx: 7Y8SWS00
Mfr#: BLS2CP4G3D1609DS1S00CEU
Type: DDR3 SDRAM
Capacity: 8GB
Connection: DIMM 240-pin
Speed: 1600MHz
Data Integrity: Non-ECC
Express delivery Order within the next 23 hours for delivery on Thursday
Hurry, only 2 left in stock!
£37.45
The Crucial Ballistix Sport Series is designed for mainstream users and general enthusiasts. A simple, slick heat spreader delivers thermal performance along with standard timings and voltages, making this reliable, quality module ideal for maximum stability and compatibility. With industry-standard specifications, little or no BIOS configuration is required. That means this product installs easily, so you can get up and going / gaming quickly. Available in both DDR2 and DDR3 in the most common and popular speeds and densities, you'll be sure to find a product that suits your needs.
  • PC3-12800 1600MHz CAS 9-9-9-24
  • Designed for Entry-Level & Mainstream Users
  • Integrated Heat Spreaders
  • 1.5v VDIMM
  • Dual Channel Memory Kit, Ideal for any Intel Sandybridge or AMD AM3 based system
  • Limited Lifetime Warranty
Specification
  • Manufacturers Part Number BLS2CP4G3D1609DS1S00CEU
  • Memory Type DDR 3
  • Memory Speed Rating PC3-12800
  • SPD Speed Rating 1600 MHz
  • Voltage 1.5v
  • Latency 9-9-9-24
  • Error Checking Non ECC
  • Registered/Unbuffered Unbuffered
  • Package Type 2 x 4GB 240Pin DIMMs
  • Warranty Limited Lifetime Warranty
Ballistix Sport - DDR3 - 8 GB : 2 x 4 GB - DIMM 240-pin
RAM memory
8 GB : 2 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz ( PC3-12800 )
Latency Timings
CL9 ( 9-9-9-24 )
Aluminium heat spreader, dual channel , unbuffered
Voltage
1.5 V
Limited lifetime warranty ( Germany - 10 years )
8 GB : 2 x 4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9 ( 9-9-9-24 )
Non-ECC
Module Configuration
512 x 64
Voltage
1.5 V
Compatible Slots
2 x memory - DIMM 240-pin
Crucial 8GB (2 x 4GB) Ballistix Sport DDR3 1600MHz CL9 1.5v 240pin Bundle deal on Crucial 8GB (2 x 4GB) Ballistix Sport DDR3 1600MHz CL9 1.5v 240pin
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £4.83 | in stock
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £4.20 | in stock
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £11.61 | in stock
Best Value Duratool Antistatic Wrist Band Best Value Duratool Antistatic Wrist Band worth £3.60 | while stocks last
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £3.58 | in stock
£56.98
saving £8.26
Including:
Intenso 32GB Rainbow Transparent USB Flash Drive Intenso 32GB Rainbow Transparent USB Flash Drive worth £5.48 | in stock
£41.54
saving £1.39
Type: DDR3 SDRAM
Capacity: 8GB
Speed: 1600MHz
Registered/Buffered: Unbuffered
CAS Latency: CL9
Standard: PC3-12800
Brand: Crucial
Price Range Inc VAT: 0 - 50
