Click to visit BT.com
BT.com
Wishlist
Crucial 8GB (2 x 4GB) Ballistix Sport DDR3 1333MHz CL9 1.5v 240pin
Quicklinx: 7Y8RWS00
Mfr#: BLS2CP4G3D1339DS1S00CEU
The Crucial Ballistix Sport Series is designed for mainstream users and general enthusiasts. A simple, slick heat spreader delivers thermal performance along with standard timings and voltages, making this reliable, quality module ideal for maximum stability and compatibility. With industry-standard specifications, little or no BIOS configuration is required. That means this product installs easily, so you can get up and going / gaming quickly. Available in both DDR2 and DDR3 in the most common and popular speeds and densities, you'll be sure to find a product that suits your needs.
Crucial Ballistix Sport - DDR3 - 8 GB : 2 x 4 GB - DIMM 240-pin
RAM memory
8 GB : 2 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1333 MHz ( PC3-10600 )
Latency Timings
CL9 ( 9-9-9-24 )
Aluminium heat spreader, dual channel , unbuffered
Voltage
1.5 V
Limited lifetime warranty ( Germany - 10 years )
8 GB : 2 x 4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9 ( 9-9-9-24 )
Non-ECC
Voltage
1.5 V
Compatible Slots
2 x memory - DIMM 240-pin
