BT.com
Wishlist
Crucial 4GBKIT (2GBx2) 200PIN DDR2 PC2-5300 NON ECC
Crucial 4GBKIT (2GBx2) 200PIN DDR2...
£51.49
2 in stock
£51.49
Add to wishlist
Delivery
Standard 3-5 working days
Micron Technology is one of the world's leading providers of advanced semiconductor solutions. Micron's DRAM and Flash components are used in today's most advanced computing, networking, and communications products, including computers, workstations, servers, cell phones, wireless devices, digital cameras, and gaming systems. Micron's mission is to be the most efficient and innovative global provider of semiconductor solutions..
Crucial - DDR2 - 4 GB : 2 x 2 GB - SO-DIMM 200-pin
RAM memory
4 GB : 2 x 2 GB
Memory Type
DDR2 SDRAM - SO-DIMM 200-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
667 MHz ( PC2-5300 )
Unbuffered
4 GB : 2 x 2 GB
Upgrade Type
Generic
DRAM
DDR2 SDRAM
SO-DIMM 200-pin
Speed
Non-ECC
Unbuffered
Module Configuration
256 x 64
Compatible Slots
2 x memory - SO-DIMM 200-pin
£51.49
Save on this ideal PC Build kit!
Save £8.29
£70.66
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Great value for money, not the easiest to install
Reviewed by Will on 08/04/2010
Compared to the official Apple RAM for my MacBook this product offers all the same features for half the price. The boost to the performance by upgrading from 1GB to 4GB is instantly noticeable and once correctly installed was recognised instantly by the operating system (snow leopard).
The only problem with the product (which isn't necessarily its own fault) is that installing it in the MacBook was very difficult. It is very difficult to push the RAM sticks in all the way (potentially a problem with very tight slots) which creates a very nerve racking moment when the computer emits a high pitched beep upon boot up and fails to launch when the RAM wasn't pushed in all the way. However, once correctly installed they work perfectly and the computer boots as normal.
The included instructions suggest that 20-30 pounds of force (100-150 newtons) may be required to push into place
Scroll to top
