BT.com
Wishlist
Crucial 4GB DDR4 2133 MT/s (PC4-2133) CL15 SR x8 ECC Registered DIMM 288pin
Delivery
Standard Due date unavailable
More speed. More bandwidth. More efficient. Next generation DDR4 memory is here.
Overcome one of your greatest server limitations: memory. From networking, cloud computing, and virtualization to HPC, Big Data and more, memory - dependent server applications require increasingly higher densities of memory and higher levels of performance than are attainable on current DDR3 technology. Enter Crucial DDR4 server memory.
This product is a 4GB DDR4 server module that operates at speeds up to 2133 MT/s and has a CL15 latency. It is a Registerred DIMM (RDIMM) with Error Correction Code (ECC). It conforms to the industry standard DDR4 RDIMM layout of 288 pins and is compatible with systems that take DDR4 2133MT/s RDIMM memory.
Crucial - DDR4 - 4 GB - DIMM 288-pin
RAM memory
4 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15
Single rank, registered
Voltage
1.2 V
4 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL15
ECC
Chips Organization
X8
Voltage
1.2 V
Colour Category
Black, green
Scroll to top
