Click to visit BT.com
BT.com
Wishlist
Crucial 4GB Ballistix Tactical LP DDR3 UDIMM 240pin 1.35V CL8
Quicklinx: 8G31WS00
Mfr#: BLT4G3D1608ET3LX0CEU
Type: DDR3 SDRAM
Capacity: 4GB
Connection: DIMM 240-pin
Speed: 1600MHz
Data Integrity: Non-ECC
Standard delivery Delivered within 3-5 working days
2 in stock
£21.76
If you're serious about gaming, we're serious about you. The Crucial Ballistix Tactical Series delivers the latest features at a price you can afford. If you want solid performance, stability, and compatibility, put the Ballistix Tactical series to work for you.
The Crucial Ballistix Tactical Series is designed for performance enthusiasts, gamers and power users. Ballistix Tactical features increased speeds and timings, and enhanced heat spreader for improved thermal performance. If you are looking for reliable, quality memory ideal for stability and compatibility while kicking up the performance factor, the Ballistix Tactical Series is a perfect fit.
Ballistix Tactical - DDR3 - 4 GB - DIMM 240-pin
RAM memory
4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin low profile
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz ( PC3-12800 )
Latency Timings
CL8 ( 8-8-8-24 )
Aluminium heat spreader, Intel Extreme Memory Profiles (XMP) , unbuffered
Voltage
1.35 V
Limited lifetime warranty ( Germany - 10 years )
4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
Speed
Latency Timings
CL8 ( 8-8-8-24 )
Non-ECC
Module Configuration
512 x 64
Voltage
1.35 V
Compatible Slots
1 x memory - DIMM 240-pin
Crucial 4GB Ballistix Tactical LP DDR3 UDIMM 240pin 1.35V CL8 Bundle deal on Crucial 4GB Ballistix Tactical LP DDR3 UDIMM 240pin 1.35V CL8
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £4.83 | in stock
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £4.20 | in stock
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £11.61 | in stock
Best Value Duratool Antistatic Wrist Band Best Value Duratool Antistatic Wrist Band worth £3.60 | while stocks last
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £3.58 | in stock
£41.29
saving £8.26
Including:
Intenso 32GB Rainbow Transparent USB Flash Drive Intenso 32GB Rainbow Transparent USB Flash Drive worth £5.48 | in stock
£25.85
saving £1.39
Type: DDR3 SDRAM
Capacity: 4GB
Speed: 1600MHz
Registered/Buffered: Unbuffered
CAS Latency: CL8
Standard: PC3-12800
Brand: Crucial
Price Range Inc VAT: 0 - 50
