Click to visit BT.com
BT.com
Wishlist
Crucial 4GB (2X2GB KIT) 200-PIN DDR2 PC2-6400 SODIMM
5.0*
Quicklinx: 584SWS00
Mfr#: CT2KIT25664AC800
Type: DDR2 SDRAM
Capacity: 4GB
Connection: SO-DIMM 200-pin
Speed: 800MHz
Data Integrity: Non-ECC
£49.65
4GB kit (2GBx2), 200-pin SODIMM, DDR2 PC2-6400 memory module
  • Module Size: 4GB kit (2GBx2)
  • Package: 200-pin SODIMM
  • Feature: DDR2 PC2-6400
  • CL=6
  • Unbuffered
  • NON-ECC
  • DDR2-800
  • 1.8V
  • 256Meg x 64
DDR2 SDRAM
4
Standard
PC2-6400
Connection
SO DIMM 200-pin
Crucial 4GB (2X2GB KIT) 200-PIN DDR2 PC2-6400 SODIMM Bundle deal on Crucial 4GB (2X2GB KIT) 200-PIN DDR2 PC2-6400 SODIMM
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £4.83 | in stock
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £4.62 | in stock
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £11.61 | in stock
Best Value Duratool Antistatic Wrist Band Best Value Duratool Antistatic Wrist Band worth £3.60 | while stocks last
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £3.58 | in stock
£69.18
saving £8.68
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £9.88 | in stock
£59.64
Customer reviews
Write a review for the Crucial 4GB (2X2GB KIT) 200-PIN DDR2 PC2-6400 SODIMM here!
Great value
Reviewed by Richard. Review Posted 05/03/2009
Upgraded my laptop running Vista as I only had 2 GB before, and Vista is mighty hungry! I do a lot of photo editing and Vista struggles if you have more than a few photos open at one time. Anyway the RAM was was easy to fit and it works fine. The laptop runs a lot better now and I can have tonnes of photos open at once without Vista complaining that I'm running low on memory.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Easy upgrade
Reviewed by Paul. Review Posted 16/04/2010
This 4Gb kit was installed in my HP laptop that had performance issues running Windows 7 Ultimate 64bit with the measly 1Gb.
The upgrade is easy as pie (make sure you follow anti-static procedures) and once installed made a world of difference.
I can now have multiple apps etc open and everything still responds quickly and when required.
If you have an old laptop and are contemplating buying a new one...don't. Install memory and a new HD and give it a new lease of life!
  • Overall 5*
  • Ease of use 5*
  • Value for money 4*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
Type: DDR2 SDRAM
Capacity: 4GB
Speed: 800MHz
Registered/Buffered: Unbuffered
CAS Latency: CL6
Standard: PC2-6400
Brand: Crucial
Price Range Inc VAT: 0 - 50
