BT.com
Wishlist
Crucial 480GB M500 SATA 6GB/s 2.5" 7mm (with 9.5mm adapter) Solid State Drive
Delivery
Standard Due date unavailable
Transform your system's performance.
New interfaces and multitasking demands require more from your system than perhaps ever before. From connecting instantly with friends and accessing apps, websites, and playlists online, to simultaneously streaming videos and downloading files, your computer is faced with an entirely new set of performance expectations that a hard drive struggles to meet. That's where the Crucial M500 SSD comes in. With data transfer speeds radically faster than a high-performance hard drive, the Crucial M500 SSD isn't just a storage upgrade -- it's a complete system transformation. From its nearly instantaneous boot times, powerful data transfer speeds, increased multitasking capability, and rock-solid reliability, the Crucial M500 delivers dramatic performance gains - all at an affordable price.
Ample storage capacity with plenty of choice.
Available in capacities up to terabyte-class, the Crucial M500 SSD provides plenty of storage for your ever-growing collection of photos, videos, music, and important documents. Based on your storage needs, choose between a 120GB, 240GB, 480GB, or 960GB drive and access your programs and files almost as soon as you click on them. If you prefer to store your data on an external backup drive, in the cloud, or on your home network, opt for a smaller capacity. Or if you'd rather have everything in one place, choose one of our larger sizes. Whichever capacity you choose, our selection ensures that you're able to find a drive that's the right combination of storage, performance, and price.
Consistently fast speeds. No exceptions.
No matter what kind of files you're working with on a Crucial SSD, you'll experience high speeds with no drop in performance across different file types. Unlike other SSDs on the market, Crucial SSDs treat all files the same, regardless of whether they're compressed or uncompressed. While many SSDs on the market achieve faster speeds by using file compression, many of the most common file types can't be compressed, resulting in SSDs that often deliver slower speeds than advertised. This is important because the files most people use every day -- videos, mp3s, advanced graphic files and zip files - are compressed files and thus unable to be compressed any further. With a Crucial SSD, the specs we advertise are the same specs you'll see in the real world.
Crucial SSDs. Performance you can trust.
Crucial is a brand of Micron, one of the largest NAND manufacturers in the world, and we design and develop our SSDs in-house using state-of-the-art technology. This means four things: hundreds of SSD qualification tests, over a thousand hours of prerelease validation testing, 1.5 billion dollars invested in R&D, and more than 30 years of industry expertise. With our multi-billion dollar commitment to NAND development, our record of patent and process innovation, and our award-winning customer support team, we're dedicated to quality. For you, that means your SSD has been designed with cutting-edge technology and it's been rigorously tested and approved. Don't settle for anything less.
Crucial M500 - solid state drive - 480 GB - SATA 6Gb/s
Solid state drive - internal
480 GB
NAND Flash Memory Type
20nm multi-level cell (MLC)
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
S.M.A.R.T.
7 mm
Microsoft Certification
Compatible with Windows 7
3 years warranty
480 GB
2.5"
SATA 6Gb/s
S.M.A.R.T.
7 mm
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
500 MBps (read) / 400 MBps (write)
4KB Random Read
80000 IOPS
4KB Random Write
80000 IOPS
Reliability
MTBF
1,200,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 22 pin Serial ATA
Compatible Bays
1 x 2.5" - internal
2.5mm mounting spacer
UL, TUV, VCCI, C-Tick, BSMI, RRL, IC, FCC, RoHS, KCC, WEEE
3 years warranty
Service & Support Details
Limited warranty - 3 years
70 °C
Resources
The following resources are available for the Crucial 480GB M500 SATA 6GB/s 2.5" 7mm (with 9.5mm adapter) Solid State Drive
Scroll to top
