More speed. More bandwidth. More efficient. Next generation DDR4 memory is here.
Overcome one of your greatest server limitations: memory. From networking, cloud computing, and virtualization to HPC, Big Data and more, memory - dependent server applications require increasingly higher densities of memory and higher levels of performance than are attainable on current DDR3 technology. Enter Crucial DDR4 server memory.
CT32G4LFQ4213 is a 32GB DDR4 server module that operates at speeds up to 2133 MT/s and has a CL15 latency. It is a Load-Reduce DIMM (LRDIMM) and conforms to the industry standard DDR4 LRDIMM layout of 288 pins. It is compatible with systems that take DDR4 2133MT/s LRDIMM memory.
