BT.com
Wishlist
Crucial 2x512MB 184Pin DIMM PC3200 Unbuffered Non-ECC
Crucial 2x512MB 184Pin DIMM PC3200...
£25.68
3 in stock
£25.68
Add to wishlist
Delivery
Standard 3-5 working days
Crucial Technology offers customers a number of clear advantages over its competitors. As the only consumer memory upgrade supplier that's part of a major DRAM manufacturer, Crucial sells high-quality memory that has been qualified and approved by all major original equipment manufacturers. That's important to customers who need quality-assured memory for mission-critical applications.
Crucial - DDR - 1 GB : 2 x 512 MB - DIMM 184-PIN
RAM memory
1 GB : 2 x 512 MB
Memory Type
DDR SDRAM - DIMM 184-PIN
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
400 MHz ( PC3200 )
Latency Timings
CL3
Unbuffered
Voltage
2.6 V
Apple M9653G/A, Kingston KFJ-E600/1G, Kingston KVR400X64C3AK2/1G, Fujitsu S26361-F2847-E130, Fujitsu S26361-F2847-E132, Fujitsu S26361-F2847-L130, Fujitsu S26361-F2847-L132, Apple 065-4976, Apple M9297G/A, Kingston KTA-G5400/1G
ABIT SG-80; Gigabyte GA-8IPE1000-G
1 GB : 2 x 512 MB
Upgrade Type
Generic
DRAM
DDR SDRAM
DIMM 184-PIN
Speed
400 MHz ( PC3200 )
Latency Timings
CL3
Non-ECC
Unbuffered
Module Configuration
64 x 64
Voltage
2.6 V
Compatible Slots
2 x memory - DIMM 184-PIN
ABIT SG-80 , Gigabyte GA-8IPE1000-G
Crucial 2x512MB 184Pin DIMM PC3200 Unbuffered Non-ECC...
£25.68
Save on this ideal PC Build kit!
Save £8.40
£44.90
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Glad that i bought these
Reviewed by on 19/08/2007
So happy with these memory modules. They boosted my pc performances by 80%. I might even buy another pair of these memory module soon. Thanks again BT for a fast delivering services.
5* Well done Dabs…again
Reviewed by Chris on 27/10/2007
Good quick delivery, memory works like a dream.
5* Easy as American Pie
Reviewed by Alisdair on 20/06/2006
I found this RAM to be the best value for money. Its the only double pack i found here saving u a lot of money. Installion couldn't be easier, Take off the cover (dont forget to turn the system off as well), remove old RAM, put new RAM in, click into place, replace cover and turn on and HEY PRESTO!! lots more RAM.
which is not a baaaaad thing haha
5* No problems
Reviewed by Darren on 12/07/2006
Good, value-for-money RAM no problem installing, no problems running
5* Good value
Reviewed by Dan O'Donovan on 29/10/2006
Excellent RAM, super zippy and reliable. What else could you want?
5* Crucial 1Gb 184-pin kit
Reviewed by Adam Simmons on 11/04/2007
Excellent product. Despite a bank holiday in between (ordered 6/4/2007), the order came before midday on 11/04/2007. Very easy to install. I originally had 2x256Mb, which were unbranded, but Dual Channel Memory mode works very well. Windows loads much faster, and games and general PC use are given a useful boost. Highly recommended.
4* Bargain Ram
Reviewed by Jimmy Lee on 02/01/2006
After Using PC2100 Ram for the last year, installing this Ram I bought from BT was the best thing i've ever done for my gaming. Easy to install, worked first time, Excellent performance. Its not Super fast, but then you're not paying super much. I plan to get another gig(2x 512MB Dimms) once I get new year out of the way.
Scroll to top
