BT.com
Wishlist
Crucial 2x1GB 184Pin DIMM PC3200 Non-ECC Unbuffered
Crucial 2x1GB 184Pin DIMM PC3200...
£54.68
£54.68
Add to wishlist
Delivery
Standard Due date unavailable
Crucial Technology offers customers a number of clear advantages over its competitors. As the only consumer memory upgrade supplier that's part of a major DRAM manufacturer, Crucial sells high-quality memory that has been qualified and approved by all major original equipment manufacturers. That's important to customers who need quality-assured memory for mission-critical applications. Crucial RAM makes your job easier.
Crucial - DDR - 2 GB: 2 x 1 GB - DIMM 184-PIN
RAM memory
2 GB: 2 x 1 GB
Memory Type
DDR SDRAM - DIMM 184-PIN
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
400 MHz (PC3200)
Latency Timings
CL3
Unbuffered
Voltage
2.6 V
Apple M9654G/A, Kingston KFJ-E600/2G, Kingston KTA-G5400/2G, Kingston KVR400X64C3AK2/2G, Apple 065-4977, Apple M9298G/A
ABIT SG-80; Gigabyte GA-8IPE1000-G
2 GB: 2 x 1 GB
Upgrade Type
Generic
DRAM
DDR SDRAM
DIMM 184-PIN
Speed
400 MHz (PC3200)
Latency Timings
CL3
Non-ECC
Unbuffered
Module Configuration
128 x 64
Voltage
2.6 V
Compatible Slots
1 x memory - DIMM 184-PIN
ABIT SG-80 , Gigabyte GA-8IPE1000-G
Customer reviews
Write review Read all The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Faster than a speeding bullet
Reviewed by Parkie on 13/06/2006
Well BT does it again! Placed the order on Sunday night - Checked the order on monday night to see that BT was awaiting stock, due in about 2 days - First thing the following morning my parcel arrives! BT exceeding expectations as usual - well done!
5* Crucial 184Pin DIMM PC3200 Non-ECC
Reviewed by Brian W on 23/02/2008
Ordered Friday arrived the next day. Excellent srevice.Fitted them Saturday to my Dell Dimension 8300 no problems at all and I am no PC geek.My ram is now 2gb instead of 1gb first class BT and crucial for making it so easy.
5* Mint.
Reviewed by Anonymous on 15/05/2008
The 'standard' delivery was there next day, mint! These 2x1gb puppies were a breeze to fit, no probs on the system and on diagnostic very stable. Great.
5* Great memory
Reviewed by Simon PAss on 27/12/2006
Early days yet but installed and was recognised my the motherboard immediately. Crucial products are great as you know from their website that the the memory will work with your PC/motherboard. Thanks to BT for saving me a few pennies.
5* ZooOM!
Reviewed by Jask on 28/01/2007
ZooOM Indeed! Amd 4000+ 64 bit proccessor Nvidia 8800 GTS 640Mb Graphics - Oh yes, its true 4x Crucial 3200 1GB 182Pin Memory - Amazing Value, Amazing Performance with graphics card 200GB hard drive 7200 RPM SLI Pro MB NForce 4 So yes, Zoom Indeed! BT Rocks!
5* Best price/capacity
Reviewed by Christo on 05/04/2006
Build a system with £720:
Asustek A8N-SLI Premium
AMD Athlon 64 3700+ 1MB
Crucial 2x1GB PC3200 C3
Gainward GeForce 6800GS GLH 512MB
WD HDD Caviar 250GB S300 16MB 7200rpm
LG Electronics DVD +- R/RW/RAM 16x DL
Sony 1.44MB Internal 3.5"
BTValue Gaming Case 480W
BTValue 30-in-1 Internal USB Reader
Upgrade potential:
MB can take 64, 64x2 and FX S939
SLI enable 2nd Graphics card install if needed (512MB will bring you a long way)
2 empty DIMM slots (2GB additional if needed, total of 4GB)
Don't bother with the true 16x SLI MB, performance is the same!
Make sure to buy the Golden sample version of the graphics card.
Box does the job and airflow is great ... MB fits perfect ... 480W is more than enough for now.
5* Low price, fat delivery and worked with no hassle
Reviewed by Peter on 14/01/2007
Fast delivery, good price, BT get *****. Crucial RAM works just fine. In 3yr old Dell Dimension 8300 3GHZ P4. BIOS and CPU-Z show new RAM working in dual channel and performance accel enabled. Exactly what I wanted - ie 1:1 800Mhz`FSB to RAM speed. I'm very happy - so ***** for Crucial too.
5* Five Star Service
Reviewed by Andy on 13/04/2007
Ordered extra RAM memory on Good Friday not expecting fast delivery.As soon as the holiday was over it was sent first class and arrived with me early Wednesday morning.Once I figured out how to open up my tower unit,it was a doddle to fit and I'm reaping the benefits of an extra two Gigs of memory.As for BT.com 100% top drawer
5* GREAT PRODUCT-GREAT VALUE-GREAT SERVICE
Reviewed by STEVE KELLETT on 12/08/2007
THIS FAST RAM HAS IMPROVED MY SYSTEM BY 25% OVERALL.
DELIVERED IN 24 HOURS - GREAT STUFF.!!!
5* 2Gb far better than 1Gb
Reviewed by T Firth on 18/08/2007
After a few days of hassle with account and address, i re ordered. Came next day. Work perfect. Great for large programmes, 100% recommended.
Scroll to top
