BT.com
Wishlist
Crucial 2x1GB 184Pin DIMM PC2700 NonECC Unbuffered CL2.5
Crucial 2x1GB 184Pin DIMM PC2700...
£42.92
£42.92
Add to wishlist
Delivery
Standard Due date unavailable
Micron Technology is one of the world's leading providers of advanced semiconductor solutions. Micron's DRAM and Flash components are used in today's most advanced computing, networking, and communications products, including computers, workstations, servers, cell phones, wireless devices, digital cameras, and gaming systems. Micron's mission is to be the most efficient and innovative global provider of semiconductor solutions.
A dual inline memory module (DIMM) consists of a number of memory components (usually black) that are attached to a printed circuit board (usually green). The gold pins on the bottom of the DIMM provide a connection between the module and a socket on a larger printed circuit board. The pins on the front and back of a DIMM are not connected to each other. 184-pin DIMMs are used to provide DDR SDRAM memory for desktop computers.
Crucial - DDR - 2 GB : 2 x 1 GB - DIMM 184-PIN
RAM memory
2 GB : 2 x 1 GB
Memory Type
DDR SDRAM - DIMM 184-PIN
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
333 MHz ( PC2700 )
Latency Timings
CL2.5
Unbuffered
Voltage
2.5 V
DELL 311-1621, DELL A0548451, DELL A0743442, DELL A0743447, Kingston KTD-PE2650/2G, Kingston KTD-WS450/2G, Kingston KVR333X64C25K2/2G, Kingston KTA-G5333/2G
Gigabyte GA-8IPE1000-G
2 GB : 2 x 1 GB
Upgrade Type
Generic
DRAM
DDR SDRAM
DIMM 184-PIN
Speed
333 MHz ( PC2700 )
Latency Timings
CL2.5
Non-ECC
Unbuffered
Module Configuration
128 x 64
Voltage
2.5 V
Compatible Slots
2 x memory - DIMM 184-PIN
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* bravo
Reviewed by Anonymous on 30/01/2006
a complete transformation for my pc! I only ever buy my electronics from BT as the service, prices and quality is second-to-none. Fantastic all round!
5* Reliable Ram
Reviewed by Benjy on 17/02/2006
Excellent Ram, I replaced my 2 x Crucial 512mb cards, which have been and still are great, and replaced them with these 2 x 1GB cards, Easy to install and a huge difference,noticeable instantly, Particularly when multitasking on multiple monitors. BT superfast delivery as usual. Recommended.
5* Wow
Reviewed by on 25/04/2007
It does what it says on the box! PC needed an upgrade from 1Gb to 2Gb RAM, you certainly notice the difference. Great value for money and you notice the boost in speed for your PC, Games have never been so cool! GET IT!!
5* exceeded expectations
Just what I wanted.... brilliant, reliable memory, fast delivery and great service! Plus it was easy to install! Highly recomended
5* A Good Buy
Reviewed by NDean on 04/01/2007
I Installed this RAM on 18/11/06 & my computer has been running almost non-stop (22+ hrs per day) since then. It is now 4/1/07 & I have had no crashes, blue-screens or weird error messages. I upgraded from 1gb to 2gb & my computer's performance has definitely improved e.g. I no longer have to do a daily restart to free-up RAM. I would highly recommend this product.
Scroll to top
