BT.com
Wishlist
Crucial 2GB DDR3 1600 MT/s (PC3-12800) CL11 Unbuffered UDIMM 240pin
Delivery
Standard Due date unavailable
Help your desktop perform at its best. Designed to help your desktop run faster and smoother, a Crucial memory upgrade is one of fastest, most affordable, and easiest ways to improve your system's performance. Crucial memory empowers your desktop to achieve faster application loading times, faster system responsiveness, and increased ability to multitask and handle data-intensive programs. What does this mean? Spend less time staring at loading screens and more time getting stuff done. Crucial desktop modules are rigorously tested at both the component and module levels to ensure that your memory meets the stringent compatibility and performance standards. Every module manufactured is inspected by the Systems Compatibility Group before it leaves the doors. At a fraction of the price of your desktop, an investment in Crucial memory helps your system get up to speed.
Crucial - DDR3 - 2 GB - DIMM 240-pin
RAM memory
2 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz ( PC3-12800 )
Latency Timings
CL11
Unbuffered
Voltage
1.5 V
2 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL11
Non-ECC
Unbuffered
Module Configuration
256 x 64
Voltage
1.5 V
Compatible Slots
1 x memory - DIMM 240-pin
Scroll to top
