Click to visit BT.com
BT.com
Wishlist
Crucial 2GB, 240-pin DIMM, DDR3 PC3-10600
5.0*
Quicklinx: 6B8HWS00
Mfr#: CT25664BA1339
Standard delivery Delivered within 3-5 working days
Crucial 240-pin DIMMs are used in DDR3 memory for desktop computers. DDR3 is the latest generation of memory with an improved architecture that allows it to transmit data more quickly.
A dual inline memory module (DIMM) consists of a number of memory components (usually black) that are attached to a printed circuit board (usually green). The gold pins on the bottom of the DIMM provide a connection between the module and a socket on a larger printed circuit board. The pins on the front and back of a DIMM are not connected to each other.
Each 240-pin DIMM provides a 64-bit data path (72-bit for ECC or registered or Fully Buffered modules). (The Ballistix™ and Ballistix Tracer™ high-performance memory do not come in 72-bit or registered modules.) Standard DDR3 240-pin DIMMs are currently available in DDR3 PC3-8500 SDRAM. Additional speeds will be added as the technology becomes available.
To use DDR3 memory, your system motherboard must have 240-pin DIMM slots and a DDR3-enabled chipset. This is because a DDR3 SDRAM DIMM will not fit into a standard DDR2 DIMM socket or a DDR DIMM socket.
The number of black components on a 240-pin DIMM can vary, but it always has 120 pins on the front and 120 pins on the back, for a total of 240. 240-pin DIMMs are approximately 5.25 inches long and 1.18 inches high, though the heights can vary. While 240-pin DDR3 DIMMS, 240-pin DDR2 DIMMs, 184-pin DDR DIMMs, and 168-pin DIMMs are approximately the same size, 240-pin DIMMs and 184-pin DIMMs have only one notch within the row of pins.
Crucial - DDR3 - 2 GB - DIMM 240-pin
RAM memory
2 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1333 MHz ( PC3-10600 )
Latency Timings
CL9
Unbuffered
Voltage
1.5 V
Lead Plating
Gold
HP 576110-001, HP AT024AA, DELL A2507433, DELL A3132540, DELL A3132544, DELL A2578594, HP NP194-69001, HP 497157-B88, DELL A3013712, DELL A3132537, DELL A3132538, DELL A3414621, DELL A3544261, DELL A3544263, DELL A3583289, HP AT024AT, HP AU742AA#ABA, Kingston D25664J90, Kingston KTD-XPS730B/2G, Kingston KTH9600B/2G, Kingston KVR1333D3N9/2G, Crucial MT16JTF25664AY-1G4D1, Crucial MT16JTF25664AZ-1G4F1, Crucial MT8JTF25664AZ-1G4D1
ASUS M4A78T-E, M4A79T Deluxe, Z8NA-D6; DFI DK X58-T3eH6, UT X58-T3eH8; Intel Server Board S5500BC, S5500HCV, S5500WB, S5520HC, S5520UR; Workstation Board S5520SC; SUPERMICRO C7X58, X8SAX, X8ST3-F, X8STE, X8STi, X8STi-F, X8STi-LN4; Tyan S7010AGM2NRF, S7012GM4NR, S7016GM3NR
2 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Module Height (inch)
1.18
Speed
Latency Timings
CL9
Non-ECC
Unbuffered
Module Configuration
256 x 64
Voltage
1.5 V
Lead Plating
Gold
Compatible Slots
1 x memory - DIMM 240-pin
RoHS
ASUS M4A78T-E, M4A79T Deluxe, Z8NA-D6 , DFI DK X58-T3eH6, UT X58-T3eH8 , Intel Server Board S5500BC, S5500HCV, S5500WB, S5520HC, S5520UR , Intel Workstation Board S5520SC , SUPERMICRO C7X58, X8SAX, X8ST3-F, X8STE, X8STi, X8STi-F, X8STi-LN4 , Tyan S7010AGM2NRF, S7012GM4NR, S7016GM3NR
Customer reviews
Write a review for the Crucial 2GB, 240-pin DIMM, DDR3 PC3-10600 here!
Crucial 2GB, 240pin Dimm DDR3
Reviewed by Ian. Review Posted 28/10/2010
Running this in a new system on a new Asus board. Very fast and does what it's supposed to do. Can't say more...except the service from BT is as usual very good and the price of this ram is very competitive. Thanks BT.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Its Crucial to get the best
Reviewed by Mike. Review Posted 31/05/2010
Quality memory is important as is reliability, Crucial and Kingston are the best I've used. I'd recommend Crucial and BT.com ***** 5stars from me:) Mike in sunny Bournemouth
  • Overall 5*
  • Ease of use 5*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
