BT.com
Wishlist
Crucial 256GB m4 SATA 6Gb/s 2.5" Solid State Drive (Inc Transfer Kit)
Delivery
Standard Due date unavailable
The award-winning Crucial m4 SSD delivers powerful performance gains for SATA 6 Gb/s systems. Designed to empower your system, the Crucial m4 SSD offers faster application load times, faster boot times, and increased durability compared to a traditional hard drive. The results speak for themselves: blazing-fast sequential read speeds of up to 500 MB/s - for any file type.
Built with advanced controller technology, Micron proprietary firmware and high-speed synchronous MLC NAND, the Crucial m4 SSD is engineered to deliver consistent, blazing-fast SSD performance. From the extensive research and development that led to its ultimate design, to the hours of testing and validation spent on each NAND component, to rigorous compatibility testing in the Crucial Performance Labs to ensure component functionality, the Crucial m4 SSD is built to last.
There's a reason the Crucial m4 SSD has garnered numerous international awards since its launch - it does what it's supposed to do. No matter what kind of files you're working with on a Crucial SSD, you'll experience high speeds with no drop in performance.
Unlike other SSDs on the market, Crucial SSDs treat all files the same, regardless of whether they're compressed or uncompressed. This is important because the files most people use everyday - videos, mp3s, advanced graphics files and zip files - are compressed files and thus unable to be compressed any further. While many SSDs on the market achieve faster speeds by using file compression, many of the most common file types can't be compressed, resulting in SSDs that often deliver drastically slower speeds than originally advertised. With the advanced technology of a Crucial SSD, however, you'll never have this problem!
Crucial m4 with Easy Laptop Install Kit - solid state drive - 256 GB - SATA 6Gb/s
Solid state drive - internal
256 GB
NAND Flash Memory Type
Multi-level cell (MLC)
2.5" x 1/8H
SATA 6Gb/s
Data Transfer Rate
600 MBps
S.M.A.R.T.
6.985 cm x 10.05 cm x 0.95 cm
75 g
3 years warranty
256 GB
2.5" x 1/8H
SATA 6Gb/s
S.M.A.R.T.
6.985 cm
10.05 cm
0.95 cm
75 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
500 MBps (read) / 260 MBps (write)
4KB Random Read
45000 IOPS
4KB Random Write
50000 IOPS
Reliability
MTBF
1,200,000 hour(s)
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
2.5" x 1/8H
Power Consumption
0.15 Watt (active) , 65 mW (idle)
Software Included
ShirtPocket SuperDuper!, EZ Gig III
1 x USB / Serial ATA cable - external
Limited warranty - 3 years
70 °C
Scroll to top
