BT.com
Wishlist
Crucial 16GB KIT (8GBX2) DDR3 1600 MT
Delivery
Standard Due date unavailable
Down on downtime? Count on Crucial server memory. Tested, qualified, and guaranteed-compatible, Crucial server DRAM delivers the power, reliability, and stability you can count on. Crucial robust product line includes the latest DDR3 modules and densities to meet the needs of all platforms and operating systems.
CT2KIT102472BB160B is a 16GB containing (2) 8GB DDR3 Server module that operates at speeds up to 1600 MT/s and has a CL11 latency. It is Registered with ECC Error Correction. It conforms to the industry standard RDIMM layout of 240 pins and is compatible with computers that take DDR3 RDIMM memory.
Crucial - DDR3 - 16 GB : 2 x 8 GB - DIMM 240-pin
RAM memory
16 GB : 2 x 8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
1600 MHz ( PC3-12800 )
Latency Timings
CL11
Dual rank , registered
Voltage
1.5 V
16 GB : 2 x 8 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL11
ECC
Module Configuration
1024 X 72
Voltage
1.5 V
Compatible Slots
2 x memory - DIMM 240-pin
Scroll to top
