BT.com
Wishlist
Crucial 16GB Kit (2x8GB) DDR4 2133 MT/s (PC4-17000) CL15 DR x8 Unbuffered DIMM 288pin
Delivery
Standard Due date unavailable
More speed. More bandwidth. More efficient.
In the ever-changing world of technology, any component more than half a decade old is usually in need of an update. At seven years old and counting, that's exactly the state DDR3 memory is in: computers can only do so much with it.
Since the introduction of DDR3 memory technology in 2007, processors have doubled in capability, SSDs have revolutionized throughput, and graphics cards have drastically increased frame rates, leaving memory as a limiting factor. With Crucial DDR4 Desktop Memory, crush the DDR3 memory bottleneck and unlock a new standard of performance.
CT2K8G4DFS8213 is a 16GB Kit consisting of (2) 8GB DDR4 desktop modules that operates at speeds up to 2133 MT/s and has a CL15 latency. It is an Unbuffered DIMM. It conforms to the industry standard DDR4 ECC UDIMM layout of 288 pins and is compatible with systems that take DDR4 2133MT/s UDIMM memory.
Crucial - DDR4 - 16 GB: 2 x 8 GB - DIMM 288-pin
RAM memory
16 GB: 2 x 8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15
Dual rank, unbuffered
Voltage
1.2 V
16 GB: 2 x 8 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL15
Non-ECC
Chips Organization
X8
Voltage
1.2 V
Colour Category
Green
Scroll to top
