BT.com
Wishlist
Creative T30 Wireless 2.0 Speakers with NFC
Delivery
Standard Due date unavailable
2.0 Wireless Speakers with NFC
Creative T30 Wireless builds on the technology of our GigaWorks T20 Series, featuring custom-made silk dome tweeters and woven glass-fiber cone drivers for excellent dynamic response, and BasXport® technology for high-output bass. It now comes with Bluetooth® capability and aptX® audio codec support to give you high-quality wireless playback and is further equipped with NFC for easy, one-touch pairing.
Tap and play
If your device has Near Field Communication (NFC) capabilities, simply tap it on the speakers' NFC receptor for easy, fuss-free pairing!
No more messy wires
Stream audio wirelessly from any compatible stereo Bluetooth smart device1 to the speakers from a range of up to 10 meters.
High-quality wireless audio
With the speakers' support for the aptX audio codec, you are set to enjoy high-resolution wireless Bluetooth audio that sounds as good as audio via a wired connection.
Primed for smooth highs and full-bodied midrange
Creative T30 Wireless features a 2-Driver Design - the custom-made silk dome tweeters give you silky smooth highs, while the woven glass-fibre cone drivers deliver natural and accurate full-bodied midrange. They work in tandem to produce an excellent dynamic response.
Get high-output bass
With the built-in BasXPort™ technology, each speaker is integrated with a large port tube to channel sound waves from the inner chamber of the satellite to the soundstage, giving you high-output bass.
Perfect anywhere
Creative T30 Wireless features an integrated line-in jack for connection to other analog audio devices, and a dedicated headphones jack for private listening. An RCA-to-3.5mm adapter is also included, giving you more connectivity options.
Creative T30 Wireless - speakers - wireless
Speakers
System Components
2 speakers
Speaker Type
2-way - active
Audio Amplifier
Integrated
Connectivity Interfaces
Bluetooth, NFC
Supported Digital Audio Standards
Apt-X
Speaker System Details
2 x speaker
Gloss piano black
Built-in Decoders
SBC decoder, aptX
2 years warranty
Speakers
Dimensions (WxDxH) / Weight Details
Left channel speaker: 8.7 cm x 17.5 cm x 23 cm / 850 g , Right channel speaker: 8.7 cm x 18 cm x 23 cm / 983 g
Enclosure Colour
Gloss piano black
Speaker System
System Components
2 speakers
Speaker Type
2-way - active
Output Features
Bass Reflex
Audio Amplifier
Integrated
Bluetooth 3.0, Near Field Communication (NFC)
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP)
Transmission Range
10 m
Built-in Decoders
SBC decoder, aptX
Apt-X
Controls
Power on/off, volume, treble, bass
Speakers Included
2 x speaker - 2-way
Driver Details
Speaker: 1 x midrange driver - woven fibreglass , Speaker: 1 x tweeter driver - silk - Soft Dome
Connector Type
Audio line-in ( mini-phone stereo 3.5 mm ) , Headphones ( mini-phone stereo 3.5 mm )
Power adapter, audio adapter
Power Source
AC power adapter
Scroll to top
