BT.com
Wishlist
Creative Sound Blaster Z PCI-Express OEM
Creative Sound Blaster Z...
£49.45
£49.45
Add to wishlist
Delivery
Standard Due date unavailable
The Sound Blaster Z, part of the ultra high-performance Z-series of Sound Blaster PCI Express sound cards, is an ideal all-round solution for your PC gaming and entertainment needs. It comes complete with the sound blaster Beam forming microphone for crystal clear voice communication.
  • 116dB Signal-To-Noise Ratio.
  • SBX Pro Studio™ technologies.
  • Crystal clear communication.
  • Advanced home entertainment audio.
  • Sound Core3D audio processor.
An ideal all-around audio and gaming solution.
The Sound Blaster Z, part of the ultra high-performance Z-Series of Sound Blaster® PCI Express sound cards, is an ideal all-round solution for your PC gaming and entertainment needs.
A signal to noise ratio or SNR of 116dB means your audio will be > 99.99% pure audio which is 34.4 times better than motherboard audio.
Experience awe-inspiring audio with the SBX Pro Studio suite of technologies that immerses you in your games and movies with amazing detail and a 360-degree true-to-life sound stage.
In gaming, if you're not communicating, you're not winning. Experience crystal clear commmunication with your teammates with the CrystalVoice™ suite of technologies that removes echoes, ambient noises and picks up your voice from within a zone (CrystalVoice Focus). It also maintains your voice level even if you move near or further away from the microphone.
The quad-core Sound Core3D™ audio processor was designed to offload SBX Pro Studio and CrystalVoice effects processing from your primary CPU, improving your overall PC performance, resulting in drastically superior audio and voice quality.
Experience like never before the power of Sound Blaster audio with your home entertainment today! With Sound Blaster Z's gold-plated connectors, speaker optimization technology and digital content encoding capability, you can be assured of only the best digital audio possible.
High fidelity surround sound
Connect to your home theatre system through a single digital cable and enjoy cinematic DVD movies by transforming any stereo or multi-channel streams into high fidelity immersive surround sound.
Never unplug your headphones again
With the Sound Blaster Z-series Control Panel, just toggle between your headphone and speaker system with a flip of a switch.
Creative Sound Blaster Z - sound card
Sound card
Enclosure Type
Internal
Interface Type
PCI Express
Sound Output Mode
5.1 channel surround
DAC Resolution
24-bit
Sample Rate
192 kHz (max)
116 dB
Microsoft Certification
Compatible with Windows 7
Package Type
Bulk
Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits)
Sound card
Internal
Interface Type
PCI Express
Audio Output
Sound Output Mode
DAC Resolution
24-bit
Sample Rate
192 kHz (max)
116 dB
Frequency Response
10 - 45000 Hz
Dolby Digital Live
Audio Modes
Playback: 24-bit 192 kHz
1 x audio line-in/microphone - mini-phone stereo 3.5 mm , 1 x headphones - mini-phone stereo 3.5 mm , 1 x SPDIF input - TOSLINK , 1 x SPDIF output - TOSLINK , 3 x audio line-out - mini-phone stereo 3.5 mm
Package Type
Bulk
Software
Drivers & Utilities, Creative Diagnostics, Creative ALchemy, Dolby Digital Live! realtime encoding
System Requirements Details
2.2 GHz - RAM 1 GB - HD 600 MB
Scroll to top
