Click to visit BT.com
BT.com
Wishlist
Creative Sound Blaster Tactic3D Sigma Gaming Headset - PC
5.0*
Quicklinx: 8092WS00
Mfr#: 70GH014000004
Standard delivery Delivered within 3-5 working days
Evolve your game with immersive 3D audio, thanks to THX TruStudio Pro Technology
Experience the evolution of high resolution 3D gaming audio with the Dual Mode sound Blaster Tactic3D Sigma gaming headset. High resolution 50mm speakers drivers unveil distinctive fine details such as weapons and foot steps with sonic accuracy, while THX TruStudio Pro Surround spatial imaging gaming audio transport you to real time battlefield.
Touch-screen software and TacticProfiles allow you to save and share your favorite settings including THX TruStudio Pro Surround for immersive 360º headphone surround and VoiceFX voice morphing technology. The dual mode design allows you to connect via standard mini jacks or use the dual mode adapter to connect to your PC or Mac's USB port for the full THX TruStudio Pro experience.
Dual Mode - Analog or USB, your choice!
Connect the headset via 3.5mm minijacks to your Sound Blaster sound system, onboard audio or MP3 player. Alternatively, use the THX TruStudio Pro Dual Mode USB Adapter to connect to your PC or Mac via USB.
THX TruStudio Pro technology
THX TruStudio Pro Surround audio immerses you in the game so you hear sounds clearly from the front, back, around, above and below. Only THX TruStudio Pro Surround delivers truly 3D audio surround effects to give you the gaming advantage you need.
High-resolution driver units
Nothing speaks more clearly of great sound than the high-resolution 50mm Neodymium drivers that unveil fine details with sonic accuracy to deliver the best gaming experience ever.
Tailor your sound with touchscreen controls
Customizable TacticControl™ driver interface optimized with Live!Touch™ for touchscreen controls under Windows 7 operating system gives you full control over every nuance of the THX TruStudio Pro audio suite as well as custom graphic equalizer and VoiceFX controls.
Customize and share optimized audio settings
Customize your own TacticProfile™ EQ and audio profiles, and then export and share them with other gamers. You can also use pre-configured audio settings from world-renowned gamers such as Fatal1ty, compLexity and Team Dignitas.
Have fun with different gaming voices
Morph your voice into different in-game characters with VoiceFX technology and restore surround audio to your Windows XP games in Windows 7 with Creative ALchemy.
Built to last
A steel core headband ensures a precise fit, and offers maximum durability for marathon gameplay.
Effortless communication with your team-mates
Use the Sound Blaster Tactic3D Sigma headset with your favorite gaming communications software such as Ventrilo or TeamSpeak.
Creative Sound Blaster Tactic3D Sigma - headset
Headset - wired
Recommended Use
Computer
Headphones Form Factor
Full size
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 102 dB/mW
Impedance
32 Ohm
Microphone
Detachable - boom
Controls
Volume
Headset
Recommended Use
Computer
Headphones
Circumaural
Wired
Available Microphone
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
Sensitivity
102 dB/mW
Impedance
32 Ohm
Diaphragm
50 mm
Magnet Material
Neodymium
Microphone
Boom
Sensitivity
-41 dBV/Pascal
Impedance
2.2 kOhm
Frequency Response
100 - 14000 Hz
Remote Control
Controls
Volume
Connector Type
2 x headset ( mini-phone stereo 3.5 mm ) , USB ( 4 PIN USB Type A )
Headset cable , Audio / USB adapter
Customer reviews
Write a review for the Creative Sound Blaster Tactic3D Sigma Gaming Headset - PC here!
Clear, thumpy and very comfortable.
Reviewed by AL. Review Posted 04/12/2012
I bought these as an upgrade for my Senhieser HD201 and let me tell you the difference is night and day but to compare high(ish) and low end is not fair.
I will say that I have sampled a good few headsets i.e the corsair 1500 ok bass but feels like tin cans with a little bit of foam pressing against your skull. And i tested the Razer Carcharias which were amazingly light and clear but probably had about as much bass as my HD201's (none).
These headsets are very confortable with the plush faux leather which are not only soft but also reduce ambient sound and provide more "ooompf". The bass has been said to be too much and affects the "highs" which i have to say in nonsense. These are crystal clear and tbh i wouldnt mind a bit more oomph (which my x-fi makes up for).
Overall at £49.99 for essentially soundblaster top-of-the-line cabled headset its a bargin.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
