Click to visit BT.com
BT.com
Wishlist
Creative Inspire T3300 - Speaker system - 2.1-channel - wired - 27 Watt (Total)
Quicklinx: 8FHBWS00
Mfr#: 51MF0415AA004
System Type: PC multimedia speaker system
Type: Subwoofer
Power: 27Watt
£44.55
High-performance 2.1 speaker system with amazing bass
Get ready to be blown away by the impressive performance of the Creative Inspire T3300 2.1 speaker system. It delivers superb bass and amazingly accurate full spectrum audio that is simply the best in its class. The speaker system comes with a large down-firing ported subwoofer with an adjustable bass level. The audio spectrum of the satellites have been fully enhanced by incorporating Creative's Dual Slot Enclosure (DSE), a design feature that produces louder mid-bass even in tight enclosures. In addition, with Creative's Image Focusing Plate (IFP) design, which improves sonic directivity to listening areas, you get more focused music that is louder, and with increased mid-bass, while retaining tonal accuracy. Now you can enjoy all the details in the audio from your desktop and many other audio devices!
Big sound from a compact system
To increase loudness and bass, speakers generally require fairly long and wide port tubes. The Inspire T3300 features the Creative DSE design, which enables the speakers to achieve louder and deeper playback even when constrained to a compact housing. This is made possible by separating the port tube into two separate slots and reconstructing them to fit into a tight enclosure.
Enjoy natural sounding audio
Our newly-improved Creative IFP design features an extended flare surrounding the satellite driver to provide an even wider acoustic sweet spot. This improves sonic directivity to the listening area, giving music more focus while preserving tonal accuracy.
Powerful subwoofer with adjustable bass
Everyone likes their bass in a different way - some like explosive thumps, others prefer it light. Simply adjust the bass level of the powerful, down-firing ported subwoofer just the way you like it!
Easy access to controls
The power and volume control are integrated into one independent wired remote control for your convenience and ease of use.
Creative Inspire T3300 - speaker system - for PC
Speaker system - PC multimedia - 2.1-channel
System Components
2 speakers, subwoofer
Speaker Type
Active
Nominal Output Power (Total)
27 Watt
Frequency Response
40 - 20000 Hz
Audio Amplifier
Integrated
Speaker System Details
2 x satellite speaker 5.5 Watt , 1 x subwoofer 16 Watt
Speaker system - for PC - 2.1-channel
Dimensions (WxDxH) / Weight Details
Satellite speaker : 8.6 cm x 9.3 cm x 17.7 cm / 320 g , Subwoofer : 16 cm x 21.4 cm x 24.3 cm / 1.87 kg
Speaker System
System Components
Speaker Type
Active
27 Watt
Frequency Response
40 - 20000 Hz
Sensitivity
75 dB
Output Features
Magnetic Shield
Audio Amplifier
Integrated
Controls
Power on/off, volume, bass
Speakers Included
2 x satellite speaker - 5.5 Watt - wired , 1 x subwoofer - 16 Watt - wired
Driver Details
Satellite speaker : 1 x high/midrange driver
Driver Details (2nd speaker)
Subwoofer : 1 x subwoofer driver
Connector Type
Audio line-in ( mini-phone stereo 3.5 mm )
Remote control
Remote Control
Remote control
Power Source
AC power adapter
Creative Inspire T3300 - Speaker system - 2.1-channel - wired - 27 Watt (Total) Bundle deal on Creative Inspire T3300 - Speaker system - 2.1-channel - wired - 27 Watt (Total)
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £14.98 | while stocks last
£54.54
saving £4.99
Type: Subwoofer
Power: 27Watt
Brand: Creative
Price Range Inc VAT: 0 - 50
