Click to visit BT.com
BT.com
Wishlist
Creative D80 Wireless Bluetooth Speaker - Black
Quicklinx: 7VQWWS00
Mfr#: 51MF8130AA004
The best value in wireless audio
The Creative D80 wireless Bluetooth speaker is an affordable way to enjoy great-sounding tunes anywhere in your home. Pair it wirelessly with any compatible stereo Bluetooth-enabled device and you get good audio without the mess of wires. It has a built-in power adapter so all you need is a power cord to connect to the mains, making setup easy and fuss-free. Take the compact Creative D80 anywhere - the living room, your study or even the kitchen - and turn up the music.
Works with any compatible stereo Bluetooth device
From a range of up to 10 meters from the speaker, wirelessly stream music from any compatible stereo Bluetooth device such as your mobile phone, notebook, iPhone.
Share your music out loud and clear
With its two powerful 3" drivers and built-in slot port-tube, share the latest hits and dance away.
Connect button
Pairing is a real cinch with the Creative D80 wireless Bluetooth speaker and you'll be done in just a few steps. You can also use the handy Bluetooth Connect button to toggle between two pre-paired Bluetooth devices.
Small size, big sound
The Creative D80 packs a solid punch despite its compact size. Move it around with ease.
Versatile connectivity options
The speaker system allows for a wired connection via its AUX-in port for other portable devices, even while it works seamlessly with compatible stereo Bluetooth devices.
Wireless audio for your computer
Do not panic even if your computer does not have stereo Bluetooth built-in. Give it wireless audio streaming functionalities with the Creative BT-D1 Bluetooth USB transmitter (sold separately). It pairs with the Creative D80 in seconds and also works brilliantly with other Creative wireless speakers.
Box Contents
-Creative D80 Speaker
-Regional AC cord(s)
-Quick Start Guide
-Warranty/Technical Support leaflet
Creative D80 - speaker - wireless
Speaker
10 cm x 10 cm x 32.5 cm
1.06 kg
Speaker Type
Active
Audio Amplifier
Integrated
Connectivity Interfaces
Bluetooth
Speaker System Details
2
Speaker
10 cm
10 cm
32.5 cm
1.06 kg
Enclosure Colour
Speaker System
Speaker Type
Active
Audio Amplifier
Integrated
Bluetooth 2.1 EDR
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Transmission Range
10 m
Controls
Power on/off, volume
Speakers Included
2
Driver Details
1 x full-range driver - 3"
Connector Type
Audio line-in ( mini-phone stereo 3.5 mm )
Power supply - internal
Power Source
AC power adapter
